5th wheel lifting bracket
twinstick
Demco makes a 5th wheel lifting bracket that looks really nice. Only problem is it's $50. I have a winch in the ceiling of my basement, that for years I've used a strap to pull my hitch out. With my new b&w hitch it would be pretty difficult to use a strap. A friend and I made a few of these lifting bracket for ourselves. Only have a couple dollars in them, and they seem to work really well. They're modeled after the ones from demco, with a few changes.
35 REPLIES 35
Learjet
whiteeye42 wrote:
if you know a welder they could make that for way less than $50 i bet there is not much more than 15 dollars worth of metal
Or just buy one for ~$50
https://www.etrailer.com/Accessories-and-Parts/Demco/DM6100.html?feed=npn&gclid=CjwKCAjwkenqBRBgEiwA...
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
whiteeye42
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
twinstick
C Schomer wrote:
I made this one about 15 years ago. 1 1/2"pipe works great.
Nice!
C_Schomer
humblerb
gkainz wrote:
i have my 6 year old granddaughter lift mine off. 😄 (Andersen Ultimate)
I, too, have a 6 year old granddaughter.
Never thought of that option.
I love these message boards for great problem solving ideas.:D
humblerb
RobWNY wrote:
I mounted a hook to the garage joist and attached an electric winch. Used a tow strap to lift it out. I'll likely just leave it in from now on unless I really have to remove it because the tabs that fit down into the rails for the pins to go through are a pain in the neck to get lined up so all 4 drop in place. My set up is so tight and precise that it took me forever to get it to drop in.
I have the same issue. I just thought the knuckleheads that installed it didn't get the rails aligned just right. I take the top off when I am not using the hitch, but leave the base in for this reason.
It would sure be nice to use my $50,000 truck bed to haul a piece of plywood again. LOL
I've got to figure out a way to get my base off (and back in) without lifting it by hand (I'm old and fat). Thought about something like an engine lift. My shop door is 10' and I can't back in far enough to use the ceiling trusses of the shop.
Me_Again
40 lbs to a 6 year old is like 150 lbs to her grandfather. :R :R :R
gkainz
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Crodad
Old-Biscuit wrote:
I just use the 5th wheel.......with 5vr hitched I pull the hitch pins and raise it using landing gear legs.
Leave it hanging from king pin.
Ditto. I just use the camper to pull it off.
2015 F-250 PSD 4x4 XLT
2016 Silverback 31RK
https://visitedstatesmap.com/image/ALAZARCOFLIDLAMSMTNVNMTNTXUTWYsm.jpg
stro1965
I have something almost identical to that. My dad made it for me years ago.
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
Dan_Henry
I made bracket to remove my BW. Took a piece of steel about 2 X 5 X 1/2. Drilled a 1/2 hole in the middle installers 1/2 eye bolt to put the hook of my chain hoist in. Put the bracket in the king pin hole close the latch then lift the hitch, I am on The road and the bracket is at home or I would post a picture.
Dan
Cummins12V98
Me Again wrote:
Here is the answer from B&W:
Chris,
Thank you for your inquiry. The head latches are strong enough to hold all the weight of the Patriot. You can lift it out of the truck with the king pin of your trailer. If you have any questions please let me know. I'd be happy to help.
Thank You,
Casey
Once again the B&W "HeavyWeights" come thru!
But this certainly does NOT suggest other hitches will tolerate such downward forces. 😉
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
twinstick
Perfect
Me_Again
Chris,
Thank You,
Casey
