โDec-27-2014 07:04 AM
โDec-27-2014 07:46 PM
Caveman Charlie wrote:
I understand you need more info. It's a 04 GMC Denali. Yes, it's a half ton but, the 1991 Forest River Salem he is looking at has no slides and doesn't seem to weigh much more then my TT. Plus, since it's a 5th wheel with the pin in the bed of the truck which is better then on the bumper like my TT has I believe he can tow it on the local flat ground we have around here.
http://www.hemmingsenrv.com/Details.cfm/750103253/1991-Forest-River-Salem/Tracy-MN/#phototabs
โDec-27-2014 12:59 PM
โDec-27-2014 10:33 AM
โDec-27-2014 10:15 AM
agesilaus wrote:
In general it is a bad idea to tow a fiver with a half ton. As mentioned above the payload is a big problem and the other issue is brakes. The manufacturers and rv salesmen will tell you you can, but once the papers are signed and the fiver is off the lot they don't care what happens. They have their money.
โDec-27-2014 09:39 AM
โDec-27-2014 08:56 AM
โDec-27-2014 08:40 AM
โDec-27-2014 08:23 AM
agesilaus wrote:
Newer model trucks may have preinstalled hitch prep packages. In that case all the buyer has to do is drop the hitch into the hitch prep holes. No installation required.
The higher prices being mentioned in this thread are for high end 'slider hitches' which may be required if the truck has a short bed and the fifth wheel is an older model. Newer, meaning less than 8-10 years old fifth wheels probably don't need a slider hitch.
Non slider hitches run in the $500-$1000 range, with some of the better models running around $900. If the owner buys the installation package (and hitch) himself from one of the many online retailers, the price will be a lot lower. Tweetys.com and Etrailer.com are two popular sellers.
โDec-27-2014 08:22 AM
โDec-27-2014 08:15 AM
โDec-27-2014 07:57 AM
โDec-27-2014 07:39 AM
โDec-27-2014 07:11 AM
