Jan-24-2016 08:54 AM
Jan-26-2016 01:32 PM
jimmyfred wrote:Bipeflier wrote:
Just curious. What brand are the axles? I've never seen 7k axles with 1/2" studs.
.............Dexter ! I'll have to check the socket size , tomorrow to make sure . It's either 13/16's or 3/4 . . jf
Jan-26-2016 08:03 AM
Jan-26-2016 07:57 AM
jimmyfred wrote:Cummins12V98 wrote:
What does your axles weigh? Have you looked into 16" "G" rated tires?
...........Trailer weighed 13,230 empty ! Now , probably 15k or so . , jf
Jan-26-2016 07:52 AM
jimmyfred wrote:
.........The Sailun 17.5 tires are available at ~$200 apiece ! But , I can't find a conventional steel wheel with 8 on 6.5 lug spacing , for 1/2 inch studs to fit my 7k axles ! Every website I have seen lists the heavy steel wheels that are made to fit either lug centric 9/16's or 5/8's studs-OR- the same steel wheel which is Hub Centric with the same two stud sizes .
..........Maybe the 8 on 6.5 wheels for 1/2 inch studs are Unavailable due to the 4805 lb. wheel rating , I'm not sure ! Anybody done any research on this issue ? , thanks , jf
Jan-26-2016 07:46 AM
agesilaus wrote:
I can't remember the last thread on here about problems with 17.5's . That , to me is significant . , jf
Maybe that's because hardly anyone uses 17.5's
Jan-25-2016 05:12 PM
Jan-25-2016 05:02 PM
Jan-25-2016 04:58 PM
Me Again wrote:
So why are you going to 17.5 rims, 16" LRG will cover your needs. Chris
Jan-25-2016 04:25 PM
Jan-25-2016 04:10 PM
Jan-25-2016 04:09 PM
Jan-25-2016 09:45 AM
Jan-24-2016 04:49 PM
Jan-24-2016 12:48 PM
RAS43 wrote:
I would be very leary of any change in offset as it could put more stress on the wheel bearings.
