Adding a water filter can I use Pex Fittings on this hose
kc81c
I'm working on adding a water filter to my RV. The majority of the plumbing looks to be regular blue and red PEX tubing but the area I need to tie into is called ACCOFLEX 1/2" IAPMO T. It is a clear and white tubing that looks like it has braiding in it and is connected to a T that goes to PEX and uses a crimp around it like PEX. I tried to stick a regular house PEX fitting in an end of an extra piece still laying in there and it fits looser then normal. I just want to know if I can use regular PEX fittings before I cut the line.
2013 Ram 2500 Megacab 6.7L
2011 Heartland Sundance XLT 285BH
6 REPLIES 6
notruffinit
I love the Sharkbite fittings (Gator bite at Lowes). Allow connections from PEX to CPVC or copper. I use them to install my water softener and when I take it out in the fall for winterization, I just release them and hook the 2 remaining ends back together. No bypass valve.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
kc81c
Thank you for the replys the rings you have in the pictures are the ones I've used with PEX fittings in the house and I have plenty of that stuff around so I will use that to install the filter today.
F4whlr
I did the same thing,however I went to HD and bought "Sharkbite" connections, so easy & simple and NO leaks.
F4whlr
2009 Keystone Cougar 318SAB
2004 Chev Silverado 2500HD 8.1/Allison/4.10
Prodigy B/C
K&N F/I air intake
Gemstone
I have used this crimp ring on the flex hose you describe with great results, thus eliminating all leak prone hose clamps that I could reach.
Apollo Stainless-Steel PEX Pinch Clamp Crimp Fitting
Regards
Gemstone
'06 Elite Suites TK3, '95 KW T-600, '08 Softail Classic , '06 Softail Deuce
pigman1
Son of Norway wrote:
I had some of that in my last motorhome. I used barb fittings with hose clamps.Miles
Same here. Another way I've worked the connections is to use a crimp ring that I got from Lowes and it seems to work with the braided hose or PEX. If you use regular copper ring PEX fittings, your connection may be a bit loose.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
Son_of_Norway
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
