Advice on 25-30 ft 5th wheel with rear opposing slides
snicker_d
I have been searching for a 25-30 ft 5th wheel with rear opposing slides and under 7500uvw. Any advice?
I've been rving about 12 years and have had 5 rigs--most larger. I've decided to downsize and lighten for travel to Canada and Alaska and then to use this unit simply for short trips--not fulltiming. I have a 38ft Teton for full time. Just looking for something that is easier on the road but still roomy and light so I don't get cabin fever.
I know Jayco makes one around 33ft but I really want to keep the ACTUAL LENGTH under 30 and the UVW under 7500 and REAR OPPOSING SLIDES IN LIVING AREA. Does not have to be new--but newer than 2006 or 2007.
Thanks for any ideas and advice. NO--NOT INTERESTED IN CLASS C, motorhome etc--I am a dyed in the wool 5th wheel type of gal
8 REPLIES 8
htowners
I'm real happy with the one in my sig, going on 4 years, but it's just over your #7,500 uvw.
KZ 275 RE
2008 Tiffin Allegro Bay 38TGB
2005 Saturn Vue
Stella and Luna, our 2 shelter rescues
Shadow_Grey
We have a 2013 29RES and really like it. It has three slides, 15K AC, full table/chairs and comes with a full queen size bed up front. It really fits us as we are on the shorter side, not needing the 13-14 foot tall trailer. Because it is the X-Lite Series it will have a lower ceiling but still all the slides and goodies.
If you are serious check out Scott at Pete's RV on the net as their brand new prices are insanely cheap. We got ours from him brand new 2 years ago for under $24k.
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
2-MTnesters
Keystone has several in their Cougar XLite series. All range from 6700# to 7800# depending on the floor plan. They do range from 31-33 feet in the style that you are looking for. Have a friend that has the 29RES model and loves it. Tim
The Webers
Me- Tim
DW- Dea
Pooch- JoJo boxer/lab mix
2010 Keystone Montana 3400RL Hickory Edition "The Taj Mahaul II"
2004.5 GMC Siera 2500HD SLT CC 4x4,6.6 Duramax/Allison, 3:73 gears, Firestone air bags, Reese 16K slider, TFI 45 gal fuel tank, Rhino Liner
patnchris
Check out Rockwood/Flagstaff. Some say it is cheaply made, but we have had no problems and it certainly tows easily. Ours has all the factory options.
Patrick and Christine
Trevor the cocker spaniel
2007 Ford F150 4X4 Max tow package
Flagstaff 8526 RLWS Classic Ultralight.
B-J1
What about a KZ Spree 265rl. I know they are under 30 ft. but not sure about the weight.
2014 Lance 825, '98 Dodge 2500 Diesel
n7bsn
That size and weight is going to be tough. That's really large for that light is, well, tough
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Grodyman
Springdale 253fwrlls. That's what I'm going with.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
