โJun-21-2017 01:50 PM
โJun-26-2017 01:22 PM
โJun-26-2017 12:26 PM
fj12ryder wrote:
I mentioned Yugos to show that people will buy anything, and continue to buy it even though it is a horrible product, cheap or not. My point, I hate to have to explain it, is that numbers of sold units are not an indication of quality.
โJun-26-2017 11:35 AM
โJun-26-2017 09:52 AM
fj12ryder wrote:
How many Yugos were sold? How many Pocket Fisherman did Ron Popeil sell? Numbers sold really mean very little since people can be convinced to buy almost anything...
What would be really telling is repeat purchases.
โJun-26-2017 09:24 AM
fj12ryder wrote:laknox wrote:Thanks for posting that, now I don't feel so foolish, or not quite anyway. I did the same thing by pinning the turnover ball in the wrong hole. I noticed some clunking noises and checked everything out and discovered my error. Like you, no damage, not even any dents in the bed from the base rocking. Just the SMH moment.
Also, from personal experience, very early on, I "high-hitched" my entire Companion in the base and didn't realize it was not firmly down against the bed, by about 1". Hell, I even torqued the entire thing! I hitched up my FW and towed it from storage to my house, about 12 miles. Felt a little different, but it handled just fine, and without any damage, whatsoever. Scared the bejesus out of me when I realized what I'd done, though! :E
Lyle
โJun-26-2017 09:11 AM
โJun-26-2017 08:34 AM
fj12ryder wrote:Repeat purchases??? If I buy a Yugo and find it to be complete junk, I never buy another one. If I buy an Andersen that meets my needs, I never buy another one. In neither case has a repeat purchase been made, but for completely opposite reasons.
"Andersen recently commented on their Facebook page that they have sold over 40,000 UH units (presumably this includes all models). This does not sound like a product riddled with issues as some would suggest. Nor should we believe that the only users are those with 3/4 ton trucks pulling light campers."
How many Yugos were sold? How many Pocket Fisherman did Ron Popeil sell? Numbers sold really mean very little since people can be convinced to buy almost anything. Like George Carlin said: "Nail two things together that have never been nailed together before and some schmuck will buy it."
โJun-26-2017 08:21 AM
โJun-26-2017 07:50 AM
โJun-26-2017 04:46 AM
โJun-25-2017 03:52 PM
Searching_Ut wrote:
For those unfamiliar with the Andersen Ultimate hitch, 100 percent of the weight of the trailer is carried by the bed of the truck, and none is carried on the ball in the bed of the truck. The truck bed ball is used as an anchor point with a pin that goes under the ball to anchor the hitch. You then tighten a bolt on on top of the tube that pulls a tub within the tube to pre-load the the base tightly against the bed of the truck. The truck bed ball is used for pulling to pull the hitch down, not to support the weight.
The other thing to keep in mind is that all of the pin weight for the trailer is transferred to the two set screws on the pin adapter between the ball and pin. The pin box not being designed to support the weight in a small area rather than distributed across the pin box base plate is what resulted in damage to my bighorn.
โJun-25-2017 11:04 AM
IdaD wrote:
He's entitled to his opinion but that's about as much weight as I'd give it too. I dont see myself ever going back to a standard fifth wheel hitch - as far as I'm concerned they don't work as well and they're more of a hassle to deal with. Just my opinion of course.
โJun-24-2017 06:23 PM
Well, for one thing, the Andersen hitch does not cause "100 percent" of the weight of the trailer to be carried by the bed of the truck.
Second, the pin weight is carried by a ball mounted on a cross member secured to the rails of the truck. Snugging down the hitch so it doesn't shift does not place pin weight on the bed. That 40 or so pounds of force is there whether or not a trailer is attached.
Finally, the problems you had with your pin box must not be widespread since yours was the first and only one I have read about on these forums. The OP is asking about failures of Andersen hitches, not pinboxes.
โJun-24-2017 06:22 PM
Me Again wrote:Maybe not at the same time, but a pulley/winch system does that very thing depending on whether it's raising or lowering a load.
You can not pull down and hold up with the same mechanism.
