laudy's avatar
laudy
another my landing gear blows fuses thread
ok I will try not to get too long with this. given the fact the gear is all the way in (retracted) and rv is hooked on the truck (reg f250 diesel no lift kit). I lower the gear approx 8-10". (I need this much out so I can lower it into level position after unhooking) After I have 8-10" out I then pull the pins on the retracted feet and drop onto wood 4x4. I then start extending the landing gear and just before it extends far enough to drive out the fuse blows. I have had this unit and truck and have not modified anything. Here is what I have tried and has not corrected the problem. Replaced switch. Replaced venture gear box. Checked all connections for tightness. Tried to operate on battery only and also while hooked up to shore power. While the unit was hooked to truck I ran the legs all the way out by hand cranking so I could feel the stops then lubricated everything with grease and silicone. Couldnt feel any bind while hand cranking but it sounds like it is laboring hard just before i get it off the truck. Same happens when I extend and try to hook truck up. So tonight Iam replacing the motor and reducer. Iam out of ideas and money after this hope it works.
