Auxiliary Fuel Tank options
tomthyme
Hey Folks!
We would like to add an auxiliary fuel tank to our F350. We have been looking at the in-bed models from TransferFlow, Titan, etc.
I would like the tank to fit under a tonneau cover.
Do you guys have any experience with these tanks?
We are also looking at the replacement tanks that mount under the truck bed. However, these make me a little nervous with possible road debris causing issues. This version leaves my bed free, which is a big deal.
What do you guys think?
Thanks so much!
2015 F350 King Ranch Dually 4x4, 22k Reese hitch
2011 Carriage Cameo 37cksls
Sarah (most beautiful creature in the world)
Mickey (105lb golden - good thing he's pretty)
Ashlee (85lb lab - spectacular pal)
Dutch (120lb lab - young one in training)
62 REPLIES 62
GoPackGo
I have an aux tank in my bed that sits about an inch below the bedrails. Then I went looking for a tonneau cover. The problem I kept running into was that many brands had components that hung down lower then an inch, even though the cover itself had adequate clearance. So I ended up going with a Truxedo soft cover roll-up. I like it much better then I thought I would. 3 years old now and looks and works great. Cannot be opened if your tailgate is locked (Yes, I know - a knife). $300 installed.
I hope you find what you want, but just in case . . . .
tomthyme
I like the Bak Revolver 2 and the BakFlip G2. I will likely go with the Revolver as it will roll up and still leave a line of sight to the hitch. I haven't checked the clearance yet on the tool box lid, but that will be a factor of course.
The two factors for me are a hard or rigid cover, and it must ride above the bed rails
minnow
What are you looking at for a tonneau cover? I'm looking for one myself that will fit over a tool box.
tomthyme
Thanks folks...all the best travels to you all!
Sport45
It does look like a nice combo from a quality outfit. You should get years of service out of it and then it will be ready for your next rig.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
tomthyme
Sport45 wrote:
...Was it much more expensive than RDS and the others?
Yes - just a bit. Most everything else I could find with an automatic pump vs. gravity drain was kicking the door in on $2000.
I paid $150 for a 'rush job' because I wanted it before we left home, then another fee for the Bed Liner. I also paid an install fee as I didn't have time to do the work myself.
Enjoy!
Sport45
You're probably better off with the external fill. If you'd put it in the box it may have required a partitioned space with a drain. This way you don't lose any storage space.
I'll have to say it looks really good. Was it much more expensive than RDS and the others?
tomthyme
Just in case you guys were curious where we landed, we had this one made to our specs and installed.
It was manufactured by ATTA in Ft Worth. We talked over the phone about what I wanted, they sent me a design drawing, I made a deposit on Monday and they installed the tank on Friday. I paid a little extra for the custom job, then a little for the bed linter spray, but we love it. The 65 gallon added capacity took us DFW to Memphis without stopping for fuel, then again on the run from Memphis to Gatlinburg. I also had them install their version of an 'auto filler pump' with a switch and gauge in the console. It automatically fills my factory tank to full when it senses that the factory tank is below 1/2.
As you can see, it is below the rails for the tonneau cover (next item to purchase). it does take up a few more inches of bed space than I prefer, but I was willing to trade that for fuel capacity. If I had it to do over again, I would specify that the filler cap be inside the toolbox section. This would make it safer and closer in height to the bed rails.
Happy trails!
larry_barnhart
We added our 55 gal inbed tank when the 05 truck was new. It has been a great item for us. I use the main tank only if needed and save that fuel for insurance if some bad fuel has been bought. Have not had any bad fuel yet but insurance isn't always needed. I have seen 100 gal tanks but that seems like big over kill.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
I am thinking about using the bottom 3" of my big toolbox as a fuel tank. It would give me about 23 extra gallons and that would be the same volume as the Titan 55 gallon replacement tank.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
GoPackGo
I figure 100 pounds for the box and then about 7 1/4 pounds per gallon of diesel.
tomthyme
bbaker2001 wrote:
2nd post, adding this extra weight, does it hurt the payload, or put you over
I don't know about the others, but it won't put me over. Good to check though!
bbaker2001
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife 🙂
retispcsi
I have a 60 gal RDS gravity feed. The fuel goes from the aux. tank to the main tank. If I want to shut it off there is a value in the line. No problems I have been using this tank for 4 years in 2 different trucks. When my truck fuel gauge moves I know the tank is empty. There also is a gauge on the tank. I use a BAK FLIP cover and there is no issues. I installed it myself fairly easy if you know your way around a tool box. The whole thing cost around $600.00. I cannot tell you how much money I have saved by being able to buy fuel at the lowest price rather then along the interstate. We fulltime.
2015 Mobile Suites 38 RSSA. 2014 Ram CC DRW 4x4 60 gal RDS Aisin 4:10.
DW, Shadow, Remington and Ron. Living the good life till the next one arrives.
