Battery disconnect on a 5'er
Dakota98
I have a friend who recently purchased a new FW from CW. We were discussing the battery disconnect & he indicated that there was one inside the coach, but when used, the slides still function. Is that common with any unit having slides & should he install something like a Blue Sea's @ the batteries ? I would think so.
My question: Is this common practice on FW's with slides & why ?
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
24 REPLIES 24
Willcamp4
I have a battery disconnect switch mounted on the wall inside one of my locked storage compartments. It is a marine style, so all you have to do is turn a knob to kill everything. Mine turns off everything in the trailer, except the solar panels that are wired direct, to keep the batteries charged. One advantage is that when the trailer is in storage, and someone breaks in (which has happened twice) the crooks can't find much in the dark.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
pete_nolin
same thing with mine, switch wired wrong
pete_nolin
B_O__Plenty
NC Hauler wrote:
B.O. Plenty wrote:
Nothing works when mine is turned off. I installed it myself. Nobody can move my front jacks if the power is off. I feel it adds a little security. I placed it inside the battery compartment which locks.
B.O.
B.O., Question:...IF your 5er is hooked to AC power, even though your battery is in by-pass, will the lights still work and can you move the slides or jacks...Mine does the same as yours when in by-pass and NOT plugged into shore power...( my by-pass mechanism is also locked to where you would really have to tear up stuff to get to it)..BUT, again, If I'm also hooked up to power, even if battery is in by-pass, I can still move slides and jacks.
Never tried it to see if the 12 volt works when plugged in with the battery switched off. No reason to. I have to turn the battery power on to get the convertor to charge my battery.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
time2roll
crcr wrote:
I'm reading here that several posters install the disconnect on the negative side of the battery rather than the positive side. Is the negative preferable? And if so, why?
Electrically it has the same effect. I prefer the positive side to stick with common convention of all switches and fuses on the positive side.
Although some RVs have multiple connections to the positive and a single cable to the negative that may simplify the install.
If it is an exposed knife switch that could short to ground it might be best on the negative.
My preference is an insulated switch on the positive.
time2roll
VERY common to have the slides and emergency brakes tied direct to the battery. These items draw NO power when not in use so the disconnect is still valid to prevent parasitic discharge.
Dakota98
First of all, I don't think it really makes any difference, but having said that, I would lean towards putting the disconnect on the "positive" side. Reason being, more corrosion will take place on the negative side & the more contact points in that line, the more chance for a shorted ground. On another note, but not related to FW's, but on TT's. If a person has an electric tongue Jack, it's also best to use the positive side on the disconnect, since the jacks are permanently grounded.
2006 POLARIS ATV
USMC 68-74
crcr
kennethwooster
Our Cameo came with a disconnect. To be honest I have not checked to see if auto levelers come on when disconnect. I really think the entire trailer is dead. Thats the way I want it.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
laknox
On my Komfort, the OEM disconnect kills everything 12v =except= the landing leg and the slides. No 12v lighting, gas detectors, TV, stereo, or anything with a parasitic draw. This includes the power converter, so my FW will NOT charge with the disconnect open (no power). I found this out the hard way. ๐Ÿ˜ž No reason not to have it this way, since there's no parasitic draw from the slides and jacks.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
NC_Hauler
Allworth wrote:
Unless the owner/user installs a positive disconnect at the ground side of the battery(ies), there is almost always some drain with the built in disconnect in the "open" position.
Almost always the propane detector. Sometimes the smoke detector; and/or slides; and/or landing gear. Pays your money and takes your chances.
Any disconnect from an auto or marine parts place will correct this.
With my battery disconnect, I have nothing working inside my 5er, no detectors, no lights, no slides, nothing...."IF" I'm hooked to shore power, My slides still work whether battery is bypassed or not.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
rhagfo
Our 5er didn't have one so I installed on the positive side of battery, I have had the unit in storage for over two months and made several trips to it turns on the disconect to run out the slides and back in for work and cleaning. We then still have power to run the slide out.
Allworth
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Dakota98
NC Hauler wrote:
On my friends 5'er, not connected to shore power & with the inside switch off, his slides still function.
Yeah, that's different..sounds like disconnect isn't connected correctly...pretty basic, cut and dry wiring job... Is there also a battery by-pass in the basement of his 5er?
No, he does not have a disconnect in the basement. That's why I'm thinking he should install a Blue Sea disconnect.
2006 POLARIS ATV
USMC 68-74
