Bedroom AC install,... questions
Our_Place
Getting ready to install a Penguin AC unit in the front bedroom of our camper. Got the roof vent removed and after three days of working at it I finally got all the lap sealant and butyl tape off the roof membrane. My question is, what do I do about the screw holes in the roof? Will the AC gasket seal them of should I put sealant on them and let it dry before installing the AC unit?
2008 Silverado 3500HD crew cab 4x4 SRW Duramax Allison 6 speed
2014 Cougar 327 RES "Campy"
3 REPLIES 3
slotsavegas
I used Rubber Roof repair tape to be sure I had a smooth and clean area for the rubber seal to contact. It has been good for 3 years so far.
fpresto
When I did it I also filled the holes. The seal does cover them but why not a little insurance in case of seal issues?
USN Retired
2016 Tiffin Allegro 32 SA
rjdlooking
I used a little lap seal just to fill the holes. But the a/c seal should cover them.
