Brand Questions and 5er Choices
irollman
So, I'm looking at replacing my Class A with a 5er. I've pretty much made the decision TO do it, the only remaining is with what and when. I live in it full time, but don't move it much - the last time I moved my Class A was a year ago. So I'm paying for something that has a lot of things that need maintenance and can break (engine, trans, etc.). I'm looking for a 5er with a good full-time living plan and storage. (I had a 5er before and it was more livable than my current coach.)
I went to a Camping World, and to a local place in PA (Tom Schaeffer's). I found two 5er plan "types" I Like. One is a raised rear living room with a shelf that pulls out from behind with a bunch of storage (Grand Design Solitude 375RES, or Keystone Montana 3791RD).
The other plan is a raised rear-bedroom with a small garage under the bed (Grand Design Solitude 374TH, also related but I don't like as much, Raptor 427). The good thing about this plan is if I decide to get a motorcycle in the future, it would accommodate it. The bad part about this plan is it gives me the option of getting a motorcycle......
Comparing the Montana to the Solitude, what are your opinions of quality? Which is better? Anything else I should look at? Remember, storage is important, but I don't want a traditional toy-hauler where the garage takes up living space.
My current location is Augusta GA area, where I'd like to make the purchase (within a reasonable distance), if it makes a difference.
I'll be getting a truck to match the 5er, already started a thread about that (thanks for all the great info there!). So consider the tow vehicle a non-issue. (Leaning towards a RAM 3500 Megacab DRW.)
Thanks!!!
27 REPLIES 27
TXiceman
You need to look at the Arctic FOx line and the VanLeigh line. The owners seem to be pretty up on things and like the quality.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Edd505
Check one of these made & warrantied for full tie living
https://www.kz-rv.com/products/durango-gold-fifth-wheels/G385FLF.html
https://www.youtube.com/watch?v=VMZtRF_w2V8
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
irollman
Iโ€™m told that Montana (โ€œMontana Montanaโ€ anyway) also honors the warranty for full timers. But I will definitely double check. Good advice!
WTP-GC
You said that you live in it full time. It's my understanding that not all manufacturers will honor their warranty if the rig is used for full timeliving. It is also my understanding that Grand Design WILL honor their warranty for full time living use. Check the fine print of the warranty.
We have a GD, but not the Solitude line. We didn't compare it to the Montana because that brand didn't have a floor plan we liked. We've been quite satisfied since day one. We've had only 2 problems: trim panl on top of the cabinets came loose (fixed with 2 screws) and the tank sensors appear to be non-functional at the panel (none of them register anything).
Duramax + Grand Design 5er + B & W Companion
SBGTF
irollman
I understand the โ€œbuy me buy meโ€ thing definitely! I am looking for something very specific (storage), and those mentioned in the original post fit the need, although they are both center island. Plus, itโ€™s going to be set up most of the time while living in it anyway. Hence the questions. Thanks for the info!
The one thing that does bug me about both is the use of the flip-down one piece steps. If Iโ€™m parked too close to something, I canโ€™t get in or out. But thatโ€™s not a deal breaker.
DutchmenSport
irollman wrote:
Iโ€™m comparing the GD Solitude to the Montana (not the Montana โ€œHigh Countryโ€. Would you call them comparable? If not, which is higher quality? Iโ€™m told the High Country is a tier down from the straight Montana - true?
My dealer referred to two different types of Montanas. He called one The High Country, and the other he called Montana-Montana. I think he called it that because it was suppose to be a step higher than the High Country.
We looked at some of the Montana-Montana's (I'm assuming these were the top of the line), and I couldn't detect any real noticeable difference between them. Maybe the Montana-Montana had more wood trim, but that was about all I could tell different. Same appliances, etc. I didn't inquire about the actual frame. We absolutely did not like any of the floor plans though. Kitchen access was always blocked in every one of them. And we looked at a lot!
I think the Grand Design might be a higher end 5er, but it was also about $15,000 higher than the Montana also. And the GD weighs in 2000 pounds heavier than the Montana, dry weight listed. So that means it's got something "more" in it than the Montana. I'm just not sure what. All I know is, the floor plans for the GD did not work for us, they didn't scream "BUY ME! BUY ME!" You know what I mean. :B
irollman
DutchmenSport
And just an FYI, the Montana has 15 windows, windows in 2 door, 2 roof vents which bring in light and 1 clear skylight for a total of 20 entry points for outside light! The entire camper, in any room feels very open. Not claustrophobic at all.
DutchmenSport
Splashers3 wrote:
Dutchman - which GD model line did you compare to your Montana? Reflections or Solitudes??? there is a difference.
Grand Design Solitude 379FLS -
Here's a video on it too: Click here.
opposed to the Montana High Country 375FL: Click here.
What we DID NOT like about the Grand Design:
With all the slides in, the kitchen and passage from front to back was completely blocked. Access to the upper living area is blocked. Although it had 2 doors for accessing both ends of the camper, both doors were are on the same side, passenger side.
What we DID like about the Montana:
With all slides in, the kitchen is still 100 percent accessible because it has no center island and it had much larger kitchen counter space, even comparing with the Grand Design with that center island.
The center island took too much away from the open space, felt cramped, claustrophobic.
The Montana, kitchen is wide open, even with slides in, can still site at the kitchen table, and access everything except the one cabinet beside the steps.
The Montana has a rear back on the drivers side and a front door on the passenger side. With the kitchen slide in, access from front to back is still blocked. But the feature of doors on both sides was the "Wow" factor that threw us over the edge.
My dealer had the Grand Design front living room in stock and we were able to see it. But I really wanted to see the Montana. He told me a Montana was due to arrive and when it came in, he'd let me know. Well, 6 weeks later I had actually forgotten about it as we decided to just settle on our current TT and not switch.
Then I got a call the Montana came in. So, that Saturday we went and looked at it, not really expecting to actually take it. By now, I was just curious to see the one I wanted to see, based on floor plans and videos. It was everything I anticipated and more!
The back drivers side door and the completely 100 percent accessible kitchen and access to the bathroom with slides in (although from the drivers side) was all it took. Actually, we signed the dotted line that same Saturday. We were actually camping that week-end, and when we got back to the campground, we couldn't believe what we just did.
3 days later, we had the Montana sitting in our drive way.
Both are very, very similar in craftsmanship, use of products, like the steps, the appliances, the fixtures, the woodwork, everything. Even the frame is the same. Both have the dropped down frame under the overhang.
The Grand Design had the gas/electric refrigerator. The Montana 375FL had the electric only refrigerator. The Montana 374FL is the same identical floor plan. The only difference is, it has a gas/electric refrigerator.
We also look at the Alpine 3711KP. Actually, that was the first front living room model we looked at. We absolutely loved the front living room and the bed room bath was something to die for. But it had only 1 door and with slides in, everything was blocked, including everything in the kitchen because of that island in the middle. We ruled that one out immediately, but absolutely loved the huge master bath and front living area.
Keystone Montana 375FL:
Grand Design 379FLS:
Keystone Alpine 3711KP:
The issues we've had with the Montana since taking delivery?
Stink bugs invaded the water heater oraface causing the water heater to fail. I finally figured this out, blew them out, and everything has been fine since.
The rear closet shelf fell on our second trip out. I rebuilt it, reinforced it, and it's now stronger than anything in my house!
There is a quick connect gas valve for hooking up an external stove or appliance outside. The valve was angled too high, not straight to the ground, making it impossible to plug in anything. In my attempt to rotate the pipe so it would be straight out, I broke the valve. it's been a nightmare getting a new one and all the parts to fit. Also, picked up a Coleman camp stove, and the very, very frustrating part is, Coleman and Keystone don't play together at all. I'm still attempting to fabricate something to connect the 2 together.
Everything else has been great! I haven't hit my head on the king pin for a couple weeks now, so I guess I'm adjusting to everything.
And yes, we picked the best floor plan that works for us. That rear door on the opposite side is absolutely great! At home parked in the drive way, that back door is actually our front door. I can back the camper in the drive way now instead of pulling forward and have the door facing the house. For us, this is absolutely perfect, being able to have doors on both sides. It fulfilled a need 100 percent!
irollman
Not Dutchman, but Iโ€™m the OP. I compared Solitude to the Montana.
Splashers3
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
DutchmenSport
Believe it or not, we compared the Grand Design and the Montana, both front living room. Check my signature block below and see which one won.
donn0128
Ot sort of depends on your wants, needs and what you can afford.
Grand design I understand makes a decent product. But as any other brand they have a range of models to fit a lot of budgets.
Northwood Mfg also has a line of trailers that offer a lot for the price. Starting with the in house built frame vs Lippert products. Their sister company OutdoorsRV are also a good product.
