โJan-24-2017 01:55 PM
โFeb-04-2017 05:59 PM
โFeb-04-2017 05:52 PM
โFeb-04-2017 07:10 AM
Lantley wrote:
IF the wind issue bothers you with a TT I will reiterate the premium hitches will eliminate this issue. You will no longer feel the push of the passing 18 wheelers. You will not feel the push of wind gust.
THe HA and PP hitches are expensive but they do deliver. BTDT
โFeb-04-2017 05:32 AM
โFeb-03-2017 08:18 PM
โFeb-03-2017 06:08 PM
goducks10 wrote:Racine96 wrote:
OP... please keep in mind that a 2500 has limitations regarding the size and weight of the FW because your payload limitations. I know I learned it the hard way.
For me the biggest difference was backing into sites. I like the way my TT used to move vs. my FW.
Can't argue that. But we tow for way longer than we back in. I'd rather have a 1, 2 or even 8 hour good tow, and then only have to deal with maybe 5-8 mins of backing up over towing a TT all day. JMHO
โFeb-03-2017 05:39 PM
โFeb-03-2017 04:06 PM
โFeb-03-2017 02:22 PM
jerem0621 wrote:
I tend to lean towards a TT. I like the flat floor, generally less entry steps. Lighter hitch that doesn't require holes being drilled in the bed (factory 5th wheel prep or not).
I like being able to use the bed of my truck while towing (not just 3/4 of it)
TT's tend to be lighter...I.e. The biggest TT 's generally gross around 12k...fivers can start at 12k lbs but there are becoming more and more lightweight fifth wheel options. I like the weight distribution hitchs. A properly adjusted weight distribution hitch with a properly loaded travel trailer and a properly loaded truck will have a great experience. The hitches generally come apart in three pieces, two spring bars and one hitch head.
I did leave off that if you want a really high end product then a fiver is the way to go because it's hard if not impossible to find a really high end TT other than an Airstream. There are some really nice TT's made today but not a whole lot at the Mobile Suites or Jayco Pennicle type levels.
They sell a lot of TT because the barrier to entry is much much lower financially.
Oh, I also forgot...there are more vehicles that can tow a TT...so if you get in a tight spot and need to pull the TT with a Full Size SUV or Van you can. With a fiver you have to have a truck with a fifth wheel hitch. Just something to think about.
Either will serve you well...it's whatever strikes your fancy.
Thanks!
Jeremiah
โFeb-03-2017 09:13 AM
sk734 wrote:
Whatever works. I just felt every time a semi went by me I was being sucked into it. My equalizer hitch did nothing for that.How expensive are Hensley hitches anyway?
โFeb-03-2017 08:06 AM
โFeb-03-2017 07:57 AM
โFeb-03-2017 06:40 AM
BarneyS wrote:
No need to worry about stability or sway with a travel trailer. You can purchase a hitch that will eliminate the possibility and make the trailer tow as well as a 5th wheel.
Hensley "Arrow" hitch
Barney
โFeb-03-2017 05:32 AM
