Butyl tape Width to reseal windows on my Outback 5er?
Like2Travel
When the weather warms up this spring, I plan to take several windows out and reseal them with butyl tape. My 5er is a 2006 Outback. If anyone has done this on a similar RV, what width butyl tape did you use and did you need to trim any off?
Thanks.
John & Evelyn
2013 Dodge Ram Larimie 2500HD 4X2 Crew Cab 3.42
Outback 28 FRLS Sydney
Dodge Builtin Brake Control
B&W Companion Hitch
2 Trojan T105's
:C
7 REPLIES 7
wgriswold
I rebed all my windows and much prefer the black 1" butyl tape. It has a little more stiffness and is much easier to apply evenly.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
Like2Travel
Many thanks for the replies. I had tried a search and never could find anyone telling the width they used. I know I can take one out and check it but I wanted to buy a roll and be ready when it warms up enouth.
John & Evelyn
B&W Companion Hitch
2 Trojan T105's
:C
pigman1
I've used 3/4" that I bought from Fastenall when I removed the driver side window to install a residential refrigerator in my 2008 Allegro Bus.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
alboy
Curious ,why not just proflex the exterior and be donre. mine is 8 yrs young ,dual pane, a little touch up thats it.
SH
Here is some 1 inch if that's what you want!
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
xaugievike
I've only seen 3/4" ish strips, but in truth I've never looked for any other. Needs to be at least as wide as the flange your working with. Better to cut away excess imo so that you know you've got product filling the area you're resealing.
2015 Chevy Silverado 3500hd DRW.
Pulling Keystone Cougar 325SRX
A buddy and I started a blog - you can read it here:
http://twoguyscamping.blogspot.com
SH
Not familiar with your rig but...most I know, myself included, use a 3/4 inch roll of tape. I think it is 1/8 thick. It does come in 1 inch wide as well. Off with the old, clean everything, on with the new, tighten frame, trim any excess, chalk around the frame. At least that is what I do!
Here is a youtube video.
Another video.
2001 Alpenlite 35RK
TST 507
