Cables and Pulleys on Slides
flyinjake
Looking at 5ers and one of the models we are considering uses a cable and pulley system rather than rack and pinion or hydraulic to extend or retract the slides. My current TT has the R&P and it seems most have the R&P system. I have also seen the hydraulic systems but mainly in the higher end models. Does anyone have experience or thoughts, good or bad, with the cable and pulley system?
Thanks
Jake
11 REPLIES 11
Allworth
Schwintek is not the only rack and pinion system out there. They do seem to be more trouble prone than most of the others.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Lantley
Atom Ant wrote:
The cable system makes me shudder when I think back to rethreading cables on my Starcraft popup years ago, but I really don't have any experience with them.
What I do have experience with is Schwintek (rack and pinion as you call it) on our forward slide and it is not great either. I have to keep it lubed, or it shuts off before the slide is actually closed, and it just sounds fragile. I'll take hydraulic anytime, but I understand with the new front living rooms and taller slides it is not always reasonable to install a hydraulic piston under the slide.
That hydraulic piston requires a hole be put in the beam. The hole itself becomes an engineering liability. By eliminating the hole designers can eliminate a lot of weight. That is the ultimate advantage of the cable system.
Otherwise both systems are mechanical with moving parts and motors that can,will and break occasionally.
Nether system is foolproof but creating a significant weight reduction is a huge bonus for the cable slides
flyinjake
Thanks for the responses and links. When I first saw it all I could think was "what a maintenance nightmare". Now I feel a lot better about it and it helps answer another question about the Sprinters.
Jake
Dandy_Dan
I have a 2009 Open Range that we have had since May 2008. It has the BAL cable system on it and we have had no trouble at all with the system. The cable system does allow the mfg to put out a lighter unit due to the weight difference between the cable system and the others.
If you Google BAL cable system you can see drawings and instructions how the system works. There are some folks that seem to think that this system is no good but they must have never been in an airplane. If you have a unit with 3 slides you will probably drop 700-900 pounds per slide by the cable system. Good Luck and Happy Camping.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
goukcats
X2 on 2.5 years with no issues. I also like the access to the motors & them being protected on the inside instead of under the RV.
Wayne & Sheryl
Plus Ollie & Sophie
(they don't know they're dogs)
2011 Ram Laramie 2500 CC 4X4 6.7 Cummins
2015 Columbus 320
"Where ever you go, there you are" Buckaroo Banzai
Atom_Ant
What I do have experience with is Schwintek (rack and pinion as you call it) on our forward slide and it is not great either. I have to keep it lubed, or it shuts off before the slide is actually closed, and it just sounds fragile. I'll take hydraulic anytime, but I understand with the new front living rooms and taller slides it is not always reasonable to install a hyraulic piston under the slide.
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
Allworth
I have cables on a bedroom slide (and R&P on the two, heavy, main slides) and haven't had any trouble. I did have to replace one cable about a year ago (the button had broken off the outer end and I don't know how long it was off. The slide worked perfectly without one cable.) but I just followed the video on the B.A.L. website and had no trouble.
A
Vulcaneer
I prefer the cable system. Have had Hydraulic as well as the cable system. Much easier to service the cable system if needed. My cables have been very reliable. And the system works as dependable as a garage door opening system. I did buy a spare cable, in case needed. About $30 but haven't needed to use it.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
Lantley
Cable driven slide systems allow for lighter trailers because the main beams do not have a large hole to accommodate the drive shafts. The net result is a lighter frame without compromising integrity.
The cables themselves are fairly reliable. They do require periodic adjustment, however it is nothing to get excited about.
Occasionally a cable may fray and break (this most often occurs if cables are never adjusted)
Cable Repair/replacement kits are sold on Amazon.
Cable slide systems are less of an issue now because the bugs have been worked out, but more importantly the techs in the field have become more familiar with the systems and are able to adjust and repair them properly.
Keep in mind traditional systems are not foolproof either. As long as there are moving parts there will be wear issues and failures on both systems. At this point cables systems are just as reliable as shaft driven systems.
I have just completed my 3rd season with no real cable slide issues other than 1 adjustment that I did myself with the help of an online manual.
Jack_Diane_Free
I also the cable system with no problems over the past 2.5 years. One of the things I like about it is that all of the motors and pulleys are 'inside' the trailer not exposed to weather and dirt. Had hydraulic before that with lots of problems.
3_dog_nights
I've been using it for a little over a year. It was recommended that I wipe down the cables in the spring to clean and check for fraying. This system had some problems a few years back but the mfg's seem to have worked that out. I can send you to an owners forum for my brand, but you can probally locate it or the brand you are looking at with a quick google search. Good luck with your choice which ever way you go, but I'm happy with mine.
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
