Care of Tires for Long Term Storage
ReneeG
In a recent article I read on how to care for tires during long term storage, it said to block the tires. Does this mean to lift them off the ground and support the axles? If so, does anyone do this? The alternative was to get the tires up off the ground to prevent absorption of ground moisture which also contributes to aging. This article suggested placing nylon blocks, similar to a nylon kitchen cutting board under each, or sheet metal over wood. What do most of you do for long term storage, i.e. over the winter, aside from covering them?
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
17 REPLIES 17
ReneeG
Thanks for the feedback RAS43.
RAS43
I cover the tires in the winter and when we are home in the summer. I don't take the weight off them, never have. When parked at home I have the tires on rubber mud flaps I picked up at a truck stop that were removed form semi trucks/trailers. Does all of this help? I am not sure but I have gone 6-8 years on tires on every trailer we have owned over the years and have experienced only one blowout. And that tire, a Goodyear, may have had a leak as indicated by the remains.
2112
FrankShore wrote:
Asphalt is the ideal parking surface. The asphalt already has petroleum oils in it, so the leaching is reduced ten fold.
On the contrary. Tire manufacturers recommend Not to store tires on asphalt.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
laknox
ReneeG wrote:
Thanks for the detailed information laknox.
Easy and cheap. Now, if I had my druthers, I'd have covered storage, block the trailer frame up, pull all 5 wheels (spare included) and store them in a dark, climate-controlled, room, wrapped in rags soaked in 303 Protectant. 🙂
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
2oldman
Dick_B wrote:
You might want to check out www.michelinrvtires.com for their advice.
Yeah. No need to do what the other guy says when reliable information is at your fingertips.
ReneeG
laknox
I got 2 8' redwood 2x6's, cut them in half and screwed one half on top of the other, with 2" set-back on one end. Working so far. In retrospect, I should have cut one 4" shorter and put it on top to keep the board from flipping up if I happen to go off the other end, where the "ramp" is the other way.
Lyle
Me_Again
Could you provide a link to where you gained this knowledge. Most tire companies advise against putting any petroleum product on their tires. Leach in or leach out?
Chris
ReneeG
Thank you for all the feedback.
JIMNLIN
Our 11200 lb 5th wheel RV usually sits from late Oct through March. The tires sit on 2x8"x36" long in the RV shed.
I slide my 12 ton stubby hyd jack under the end of each axle tube and rotate the tires 30 degrees or so a couple of times a winter.
I use LT tires on all of my trailers including the RV. I run the RV tires usually around 7 years on average and 45k-55k miles. LTs on my equipment and flatbed trailers 8+ years as they sit empty , out of the sun, much of the time anymore.
Years ago when the biggest camping trailer (RV) was in the 22'-24' range ,most were less than 20', many folks jacked the trailer off the tires for winter storage. Todays trailers are much larger/heavier = much more dangerous for the average Joe to do the job and do it safely.
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
FrankShore
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk båt - Dette må jeg se!
larry_barnhart
We will be due for tires next June. We never cover our tires for the 6 months of winter because of buying new at 5 years. I do cover at home, doesn't seem to make good sense but less stuff to carry for the winter.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
larry_barnhart
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
