โMar-24-2021 03:38 PM
โApr-14-2021 06:45 PM
Grit dog wrote:
Sounds like some of y'all should fix the gas leaks on your "toys"....
I don't believe that it's coincidence that in 20 years almost of storing bikes and sleds in enclosed trailers, year round, I never have smelled gasoline fumes inside unless something was leaking or I was filling the tanks.
โApr-06-2021 12:51 PM
Huntindog wrote:lincster wrote:LOL. Close.
Wow. Are you going to Antarctica or something?
I would just go buy fuel and/or propane.
The north rim. The highway in has a locked gate. Propane and gas may or may not be available without a long drive. Basically we need to take what we expect to need with us. I hate to waste a day running around after supplies.
I once had the propane regulator fail at the begining of a hunt there. Temps were in the low teens, and no propane getting past the regulator meant no heat. I had to run into Flagstaff to get a new one. That wasted an entire day, and a lot of fuel. I now carry a spare.
โApr-06-2021 12:30 PM
โApr-06-2021 06:47 AM
โApr-02-2021 10:43 AM
Dirtclods wrote:valhalla360 wrote:
Look at killing all the 12v in the house (even if the gas is in the toy's tank). I wouldn't trust these devices to be ignition protected.
Obviously, you need to keep brakes & brake lights connected.
Look at killing all the 12v in the house (FRIG) = Runs off the house batteries.
โMar-29-2021 06:54 PM
wopachop wrote:I have done a lot of automotive AC work. As result, I have an awesome O ring collection.:BHuntindog wrote:I hear you. Typing this inside a toyhauler sitting in the garage/dining area. Gas cans can seal really good. If yours dont you can buy the big black oring for the main cap. If the little vent doesnt seal you can probably buy that as well. I recommend buying the green nitrile oring set from harbor freight. That set has saved me so many times. I fixed a darn leaking kureig coffee machine once with them. There is a size that works perfect for the gas can vent.wopachop wrote:The toys come out at camp. The garage becomes a dining/sleeping area
Only issue will be smelling gas if you need to sleep in the toyhauler with toys in it.
The toys actually have a vent that can fail. Its supposed to allow air into the gas tank, but not let fumes out. Ive had to sleep in my trailer with toys in the garage and its not fun. Those fumes are no good. My trailer has a front bedroom and even with the doors shut and windows open i will taste gasoline in my mouth for days.
Point being gas cans should seal 100%. Storing them inside your toyhauler is no big deal if done safely. Ive read the plastic itself is pourous. So its horrible for long term storage. But traveling with a common 5g gas can inside the toyhauler is very common.
โMar-29-2021 05:57 PM
lincster wrote:The bed already has B&W Companion, and 60 gallon aux. diesel tank. I am bringing 5 spare propane tanks, and then will fill the rest of the bed with fuel.
I don't do this.
I put my extra fuel in the bed of my truck.
I carry 60 gallons in cans in the bed and still have plenty of room for wood etc.
โMar-29-2021 01:46 PM
โMar-29-2021 12:36 PM
โMar-29-2021 09:18 AM
โMar-29-2021 05:57 AM
โMar-28-2021 08:09 PM
โMar-28-2021 05:32 PM
โMar-27-2021 11:50 AM
dedmiston wrote:Depends on how cold it is. The weather fluctuates a lot on the North Rim, and there are no weather reports worthwhile. I am bringing five 5gal spare tanks. Some of the coldest temps we have ever camped in were there.
2.5 weeks. Man. That sounds great.
Will you really run out of propane?
