carrying up front
pdarby
I am currently pulling a Big Horn 3370RK with a 13' Ford F-250 SD 6.7. I am thinking about mounting a receiver hitch on the front of the truck and carrying a 3 to 400# scooter on the front. Anyone else doing this? I have seen it done before. Ideas??
22 REPLIES 22
jus2shy
avvidclif1 wrote:
jus2shy wrote:
avvidclif1 wrote:
jus2shy wrote:
Just a quick note. You're putting 300 to 400 lbs on the front of your truck. However, your fulcrum is your front axle. So even though you're putting 300 lbs on the front of the truck, you are also going to pull a few hundred pounds from the rear as well. So you may be putting an additional 500 or 700 lbs on the front axle of your truck. It'll help spread more pin-weight to the front axle and give your rear axle a little relieve, but you already have a heavy engine on the front tires. Also note that you will have yourself and anything between the tires putting some weight on the front axle as well. Check how much overhead you have.
California Physics???????
That 500 to 700 is inclusive of the scooters weight. Regardless, you are going to have a teeter totter effect. So you do pull weight above the scooters towards the front. The same principle allows a weight distribution hitch to put weight on the front axle, using the rear axle as the fulcrum.
The fulcrum on a weight distributing hitch is the hitch itself, not the rear axle, think about it. The rear of the truck goes up and the front down, it doesn't pivot on the rear axle.
Yeah, I figured that out after I posted and thought about it for the night. I think a better example is just a regular ball hitch with no weight distribution, then your rear axle is a fulcrum and you're taking weight off of the front of the vehicle. Therefore you're adding the tongue weight plus some of the weight carried by the front axle to the rear axle.
Bah, here's a quick calculation. I don't know the wheelbase of the OP's truck, but say he has 10' between the tires, and from the front axle to where the scooter will sit forward of his truck, he has about 4'. Let's also assume the scooter weights 400 lbs for simplicity's sake.
The scooter will be putting down a force of about 1600 lbft from where it sits in front of the truck. The other side would be putting down the same amount of force to keep the "teeter-totter" level. So since the front axle is the fulcrum in the OP's case, the rear axle would stand to lose about 160 lbs of weight because of leverage being taken into account. But the overall mass exerted onto the front axle would actually be about 800 lbs. As for every reaction, there's an equal and opposite reaction. Simple teeter totter equation: Mass1 x distance1 = Mass2 x distance2.
I know it's bad to use imperial units, as most physics is done in metric but I figure these units are easier to relate to. Also, it's been a while since I've thought about leverage and statics and stuff.
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
avvidclif1
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
TXiceman
As noted, the OP is probably over the trucks GVWR to start with. The OP needs to head down to the scales and weigh his truck and trailer. Most diesel pickups are very near the front axle GVWR without hanging an additional 300# plus on the front.
The scooter may well over load the front axle. Then you have the issue of blocking the radiator and also the lights and turn signals on the front.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
jus2shy
E'Aho L'ua
avvidclif1
Clif & Millie
jus2shy
E'Aho L'ua
Mike_Taverniti
Just did 9,000 miles with 2 bicycles on front of 2004 GMC 2500 HD. Had too replace front wheel bearings and some other suspension parts when we got home ! Not sure if extra weight contributed or just time for new parts on a 10 year old truck !!
Super_Dave
A scooter isn't a solid wall and it doesn't sit tight up against the radiator, so, I think too much is made of that concern. I carry a basket up front quite often.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
kennethwooster
I have had 2 F250s pulling 5th wheels. Both were overloaded and required air bags. Adding more will not help. I dont think enough air would be restricted to hurt. Some of the grill guards used here with ranchers will restrict more then probably what you would put there. Overall weight is the problem.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
MFL
Nomad II
Nomad II
I also have a 13 250, with heavy duty service suspension. My yellow sticker payload is 3,232.
I could handle a 12,000# loaded weight FW, plus hitch, gear, and passengers.
I would have no room left for a front hitch, plus weight of carrier, and a 3-4 hundred # scooter.
I also don't see the need for sarcasm, but since the OP asked what do you think, I would say you will likely be over loaded, and could cause cooling problems.
Jerry
Yeti_plus
I had a front hitch on the old truck and have installed one on the new truck. My trailer is smaller than yours, but I carried a Honda Jazz on the old truck. The Jazz is only 50CC and weighs about 150lbs. I had no problems with overheating or airflow.
I wouldn't put my 250 cc Honda Reflex on the front, because it would block the headlights and being that much larger may impede airflow.
The other problem would be my rack pivots in the middle to facilitate loading the scooter and the centre of gravity with the bigger bike is on the wrong side of the pivot.:S Makes it real hard to load. Now I want to get a scooter in between the two and rather than a test ride ,I want to do a test load on the carrier.:D
Good luck in your search.
Oh and as someone else said, be careful with the extra 2 feet out front, it makes it sooooooooooooo much fun backing into a tight campsite!
Brian
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213 SOLD
2008 Bigfoot 25C9.4
Lantley
57 Panhead wrote:
donn0128 wrote:
Sure why not. No reason not to whats another 300 pounds when your already overloaded
And you know this how?
No need to comment at all if you are just going to be sarcastic and arrogant. I can never understand the need some feel to make cutting non productive comments here.
To the OP, the only concern I would have as stated above, is the effect it could have on the air flow to your radiator and tranny/oil coolers.
Steve
Be concerned about the additional weight as well. 300# directly on the font axle is significant.
The OP has an F-250 3/4 ton. He is already pushing his limits.
Before putting 300# on the front a trip to the CAT scale would be wise.Otherwise it's all a big guess.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
socoguy
No need for the sarcasim. A more informative reply would be more constructive. The specs on the Big Horn 3370RK would indicate it would not be the best decision.
Regardless of the configuration of the F-250 (SB, LB, 4x4 ext cab or crew) the pin weight of the 3370RK has to be close to payload without people fuel or hitch.
I would say don't do it. JMHO.
jlp16au
Dry weight of the camper the OP listed is 12,095 lbs. Dry hitch weight is 2375. The GVWR of the camper is 15,500 lbs. I would be willing to bet the wet and loaded hitch weight is in excess of 2700 lbs. A F-250 crew cab lariat 2wd typically has a payload capacity of ~2400 lbs which is before the hitch is installed and anyone or anything is in the truck. If it is a 4wd then the payload capacity is typically around 2000 lbs. Unless the OP has a more stripped down truck or a regular cab, I suspect donn0128 is correct in his assessment.
