Checking Truck For Level?
Super_Dave
Is it safe to assume that putting a level on the truck bed rail when loaded would indicate how level the overall truck is riding?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
12 REPLIES 12
Cummins12V98
Truck LOOKS level.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ETCrockett
mtofell1 wrote:
Cummins12V98 wrote:
Park on flat ground. Stand back at the side, does it LOOK level???
Yeah.... I'm kind of in favor of this method. I guess the question is what is trying to be achieved by having the TV perfectly level? I understand the 5th to TV and bed rail clearance but I can't see a problem with a TV being a few degrees one way or another off level. Certainly, the trustworthy eyeball test Cummins eludes to should be close enough.
I agree about the bed clearance and the FW towing level. However, you want to also avoid excessive squating on the TV when loaded. I have always been told that when towing from the bumper hitch that excessive squat puts a strain on the drive shaft and cause major problems. I just assume the same would be true when towing a FW.
Eric & Andrea
2016 Jayco Pinnacle 38FLSA
2009 Ford F450 DRW
edbehnke
relax. just do a visual...that will do it. and even if it isn't there isn't a lot you can do unless you have air bags.
eddie and sandie
3402 Montana 2013
Ford F350 2015
mtofell1
Cummins12V98
Super_Dave
Parked on flat ground, I put an 8', 2x4 on the bed rail and a long level on the 2x4. The rake over 8' is about 2.5" when loaded.
Slownsy
Super Dave you are correct, but as also suggested check that you are parked on a level surface.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
goducks10
Super_Dave wrote:
Goal would be to evaluate whether pin weight put truck in rear end squat below level from empty, ass high position. I don't think that involves fender well clearances unless I'm not understanding how that pertains to truck being level when loaded.
I assume that the fender wells are the same off the ground when the trucks level. I thought all MFG built them that way. What else would you use to check level? Mine's 3" higher in the rear using the fender well when empty.
Using fender measurements takes the guess work out. Don't have to be on level ground.
Super_Dave
Old-Biscuit
Place level on bed rail with trailer NOT connected.
Note have much 'rake' your truck has
Then do same with trailer connected
Measure front tire to fender with trailer not connected AND connected
Much difference?
Shouldn't be with dually and 3200# wet pin (16K GVWR/20%)
laknox
Lynnmor wrote:
No, that doesn't consider the surface you are parked on. Best to measure and record the empty truck fender opening height at each wheel, then compare that with the loaded measurements. Of course you might want to bring the rear down more than the front.
With a 4' level, you could check the surface, then compare to the bed rail. :B
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Lynnmor
