Columbus Auto Leveling System
bigdog112
We are close to buying a new Columbus 320RS and I was wondering if someone could tell me if the auto level system is hydraulic or electric. I am considering this option but I am curious which system the factory is using. Thanks in advance.
16 REPLIES 16
Duck
bigdog11 wrote:
I called the dealer today and they said that it was the hydraulic system. From what I have read here I will probably to ahead and get that option. Thanks for all of the advise.
Might want to double check. I had a Jayco dealer tell me the same thing but when I talked to a Jayco employee at the RV show he told me that it was electric and not hydraulic.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
Paul_Clancy
Just FYI the latest electric system is lipperts ground control version 3 with auto rear jacks (no pins to pull). I have version 2 and like it very much but v3 seems like a nice upgrade with faster levelling.
bigdog112
Thanks Wildcat for the info. I will see the unit on Saturday for the first time. It is a Columbus we are going to purchase but it sounds like it will be with the electric leveling system. By the way, who do you sell for? I know, I know, it is probably against the rules to answer that, pm me if you want.
2008Wildcat
Then they aren't selling you a Columbus.
Columbus does not offer a hydraulic leveling system.
I sell them everyday and there is no option for it.
2013 Columbus 320RS
2011 RAM 3500 Outdoorsman SRW 6.7 Cummins- tweaked!
bigdog112
bkd234
We have a Columbus 320RS and have the Lippert 6-point Ground Control II electric leveling system. At setup, you do do have to manually pull pins and lower jacks legs a few inches off the ground before starting auto level. When you get ready to leave, you auto retract and then raise all jack legs and secure with pins. The system does a good job of auto leveling and with strong arms we are pretty solid. I believe the Level Up system is fully automatic.
Pete_k
Not the same camper. But love the auto system on my Heartland Key Largo. And will never own a unit without it again.
Pete
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
dapperdan
I'd say go for the auto level system. I can't address Columbus but I wish we would've "sprung" for the 6 point level up system on our '11 Montana. We bought our unit (new) off the lot but I wish now I would've done just a bit more home work and been more educated on leveling systems. It's just an added feature, is it necessary? No but I haven't run into one person yet that regrets having auto level.
I wish we had it, oh well maybe there'll be a "next" trailer and if so that one WILL have it!
Good luck with your decision.
Dan
2008Wildcat
Columbus does not use any hydraulics on their trailers.
I have the Lippert 6 way levelers on my 320RS, and they are electric, and work fine.
Get the Strongarm stabilizer package, and it sets up solid as a rock.
There are benefits and downfalls to both systems. If you have the hydraulics, and it gets a leak, nothing works. No slides, no jacks. At least the electric ones can be worked manually if needed, as each jack has a motor and override on it.
All the shake and wiggle comes from the axles, suspension and tires, so it really doesn't matter that they are not at the rear of the trailer.
2013 Columbus 320RS
Duck
The cost you mentioned, 2k, is what the option for the hydraulic 6 point system cost on my trailer,
Don
08-FORD F350 PSD
topjimmy
We got the Lippert hydraulic 6 point auto level and everybody is right it is the best thing to come along on 5th's for a long time well worth the money for me, I have had it on my Montana for 2 years and it has been trouble free
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
Rob_Fla
Lippert also has a 6 Point Electric Auto Leveling System
2014 Redwood 38FL
2018 RAM 3500 DRW
frac999
I have a 6 point Lippert Hydraulic system and its the best thing since indoor plumbing. You unhook push the auto level button and stand back and watch. Your traveling partners will be mad at you. The jacks are so much faster than the electric.
bigdog112
I took a look at the quote again and it says 6 point leveling system so I will assume it is the hydraulic. We are going to look at the unit this Saturday. It is an extra 2k for the leveling system. The have the identical unit without the system so at least I have a choice.
