converter
silverthunderro
Needing advise on getting a new converter i have a wfco 9855 and by trouble shooting it I'm in the market for a new one....So any info would greatly be appreciated
2005 Dodge, 24 Valve, Turbo Diesel Cummins
2009 Copper Canyon Fifth Wheel, Reese Slider Hitch, Prodigy Brake Control
10 REPLIES 10
silverthunderro
Ordered a converter from randy at best converters today really nice folks to deal with and seems to have good priceing on his products
silverthunderro
Thanks everyone for the info will do some calling monday
cyntdon2010
I also purchased from randy @ best converters.
you wont use that wfco brand.
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
pianotuna
Nomad III
Nomad III
Iota, PD, and Boondocker are all good converters. Talk to Randy at bestconverters.com
Regards, Don
ScottG
silverthunderroad05 wrote:
Does the 9200 hook to shore power with a cord or do you have to hard wire it
The 9200's have a grounded male plug coming off them. You can cut it off (at the expense of your warranty) or you can do as I did and install a receptacle that is then hard wired to the main breaker.
silverthunderro
Dakota98
I'm reasonably sure the consensus you'll get here on the Forum will be
Progressive Dynamics & in your case, as stated above the PD-9260c
And to purchase one, call Randy @ 888.828.1893
BEST CONVERTER
You won't have to press "1" for English or "2" for Spanish & he's a good looking fellow too.
Disclaimer: I have not received any compensation for this referral. :B
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
silverthunderro
Ok thanks I will check into it..
Splashers3
Last fall I replaced my WFCO 9855, which had died, with a Progressive Dynamics, I think 9260 (it's too early to run out in the dark and check)...I love it! ( I carried it as a spare for almost the whole season, as the WFCO was indicating it was going bad) I ran the charge wizard through the back of fuse box and can see it flashing through the fuse box window under the television...so I know what the battery is doing by the rate of flashes.
This converter would be my recommendation.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
bbaker2001
handy Bob has talked a little about this. I can tell you that if you are getting a converter --charger, you need to find one that you can set to what your batteries need to reach full charge. most do not do a good job.
I have been looking Randy at bestconverter.com
he is very knowledgeable and can give good answers. my Trojan batteries need to go to 14.8 and stay there for a while
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
