โApr-19-2011 05:12 PM
โApr-22-2011 10:45 AM
โApr-22-2011 10:29 AM
โApr-22-2011 09:57 AM
โApr-22-2011 07:30 AM
โApr-21-2011 10:20 PM
โApr-21-2011 10:10 PM
rock-rod wrote:
definitely an interesting idea...
I don't think powering both axles will cause any binding. OTR tandem axle trucks power both axles through a common drive shaft and they don't have any issues. The tandem axles turn on a similar arc so there shouldn't be any windup in the drive line.
I am curious about two potential issues though:
How are you locating the secondary axle? Is it by a 4 link with air bags? It almost appears you have a 4 link suspension, however the links are pivoting from the rear of the frame? Have you thought about how this will function under load? Anti-squat comes to mind with the positioning of the links.
Second, if you are planning on using the secondary axle brakes, how will you tie those into the existing hydraulics? Have you come up with a master cylinder that has the capacity to move two additional wheel cylinders/calipers?
Finally, the drive shaft routing from the t-case will get interesting. It seems to me that it's going to take a lot of thought in the Ujoint phasing and angles to snake around the middle axle, and keep all the joints in companionship angles so that they cancel each others vibrations. There's always the CV route, but I don't think there's one in existence that can handle the torque of cummins.
Food for thought....
โApr-21-2011 10:05 PM
โApr-21-2011 09:19 PM
โApr-21-2011 09:09 PM
Ductape wrote:
Part time operation unless you need the traction is a good idea. IIRC there were some Fords back in the 70's with a divorce mounted full time transfer case. NP203? If so a 203 may or may not be up to what that Cummins will send to it.
โApr-21-2011 08:25 PM
โApr-21-2011 05:26 PM
โApr-21-2011 05:16 PM
โApr-20-2011 01:24 PM
SoCalDesertRider wrote:
Securiti,
Even though tandeming the truck is not how I would have gone about increasing the trailer towing or hitch weight hauling ability of the truck, it is an interesting and fun project none-the-less that I will follow as it progresses here on the forum. I lend my support to the idea. ๐
โApr-20-2011 10:56 AM
Bacon5 wrote:
First thing I thought of when I saw this was how many times I've been buried in the sand at Pismo Beach. I'm thinking you would have no issues there.
When should I have my truck delivered for the conversion?
โApr-20-2011 10:03 AM
