Correct Track
Veebyes
Corrct Track
Has anyone installed the product themselves?
By the basic alignment measurement of the fist between the wheels it appears that my alignment is out. Have uneven tire wear as well.
The biggest challenge seems to be getting spring hanger bolts out & back in.
2007 Alpenlite 34RLR
11 REPLIES 11
MM49
goducks10 wrote:
Here's a video showing the flex in correct track.
https://www.youtube.com/watch?v=Bp5iRVPwYZg
The LT advocates should take a look at this video. Then they should have someone explain the torque introduced into the suspension system by axle movement. The LT taller tires along with the stiffer side wall combine to create more leverage on the suspension mounts. The suspension mounts are mild steel and can be damage when flexed too far or too often. The RV suspension system benefits from the ability of ST tires to be flexible yet have a tough sidewall construction. The frame and suspension of a RV work together as a system to absorb stress and transmit to areas of the frame that can handle it.
MM49
B_O__Plenty
Seeing that video convinces me that the add on Correct Track isn't something I would want. The last time I had my trailer aligned at a frame/suspension shop it was under $300.00 if I remember correctly. It only takes a couple hours.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
goducks10
Veebyes
I've had a wheel alignment/axle straightening job done in a truck/trailer shop on a previous trailer. That was 8 years ago & I recall the bill being near $1000.
I understand that the Correct Track system adjusts only the axle alignment. I am all but 100% sure that my axles are out by the difference between tires each side & Correct Track should correct this.
Individual wheel alignment through axle bending is another matter. Hoping all is good on that side of things.
I'll be doing the install in a boatyard so I will have access to all kinds of tools & blocks short of using the travel lift to pick up the trailer & hang it 6' off the ground.
B_O__Plenty
Correct Track will not not give you a true alignment. It will adjust the tracking which is how square the axles are with the frame and each other, but nothing else. It does not allow for adjusting toe in or our which is the wheels pointing toward or away from each other and it does not allow for adjusting camber which is how straight up and down the wheels are. In addition the fact that it lifts the trailer up also allows more leverage to the spring hangers and frame rails and there have been reports of them twisting as the result of this. I would just go to a good heavy duty truck frame/suspension shop and get a good alignment done. probably for the same or less money as well.
B.O.
Yup I'm a fanboy!
routemaster
I did it myself with the help of a buddy I have a new LTZ and that is 2ins higher than my old LLY. It took us 27 hours to complete the job the videos I watched made it look easy. I myself did not find it so.
Drilling from the rear side was not so easy with the belly and pipes low point valves in the way. But it did lift the coach up the 2ins and my tracking was ok by the last check I had, so I used the centre point of coin.
2017 Landmark Arlington 365
2015 Silverado LTZ 3500 c/c LWB.
AZ_T_T
Veebyes wrote:
AZ T&T, you can be helpful. The description of the kit is not very clear. I assume for the price the hardware is supplied for all 6 springhanger points, correct?
Figuring out what to do does not seem difficult. Make sure the fron axle is as it should be first by dropping a plumb from the kingpin & measuring any differences each side, same point, on axle or U bolt. Then do the same for rear axle.
Going to take time but my DW is a well trained boatwoman so she is very useful when it comes to helping with repairs & modifications.
I especially like the reinforcing spacer block that fits inside the springhangers. The lift will be useful too as on occasion tires have been rubbing on the bottom of the slides.
I wish I could answer that for you but I never saw mine until it was installed.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Veebyes
Smkettner, that is ugly.
Nope, my springs are good. Upgraded from a 6 to 7 pack in 2013. Running BFG Commercials so have some good rubber too. Also already have the Equaflex system installed.
We do between 15,000 & 20,000 trailer miles a year. There is no skimping on the running gear underneath us.
time2roll
I thought mine was out of alignment. Turns out the springs were sagging.
I thought I had bad wear due to alignment. Turned out my tires had slipped or broken belts.
Really need to remove the tire to inspect.
Veebyes
AZ_T_T
I know your question is about installation, unfortunately I had mine installed by the company who lifted my FW. I just wanted to chime in and say I love the Correct Track! It's great being able to keep the axels aligned.
Good luck!!
AZ T&T
