Daydreamer furnace wont ignite
MPI_Mallard
Right, fall has arrived and it's time to migrate south but not quite yet so I hit the swich to fire up the furnace to take the chill out and all I get is fan, no heat. Any suggestions??
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blรผcher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
3 REPLIES 3
MPI_Mallard
I checked the exhaust and it's clear, I tried starting it with all the other propane appliances working and nada, then I cycled it three times and on the third time it ignited and I felt hot air coming from the vent then after thirty seconds or so the burner shut off.
Red Green:
NC_Hauler
Was your exhaust vent open all summer? May have an obstruction in it, like a mud dauppers nest...happened to me once...fan fires up, tried to ignite and just went back out...but it DID try to ignite...had to pull the exhaust pipe out and was able to break loose the nest...presto, worked great afterward...I cover it with white duct tape in summer months.....
......or as other posted, might be an issue on your circuit board.
hope you get it fixed soon and to your liking.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Mandalay_Parr
The blowing air from the fan has to activate the sail switch before ignition.
Are your batteries very good?
Are you plugged in?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
