King Control Jack Antenna
remdog_1
Had Jack over the air HDTV antenna installed 1 year ago. Been working fine until now. Has power to antenna booster and roof attenuator inside of camper. Power light is on, however when I attempt to turn antenna to get best signal, I have no green lights for signal. When I attempt to scan in channels it is not picking up any. I have TV set on AIR, not cable. I have also checked all fuses. Any suggestions?
8 REPLIES 8
SailingOn
Check all the connections. They corrode. They vibrate loose.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
Snow: 2020 F250 diesel
AD5GR
SCVJeff
JEBar wrote:
when a Jack antenna is used to replace and OEM bat wing, the signal booster that comes with the Jack should not be used .... the OEM signal booster (the one controlled by pushing the small black button on the plate where the coax is connected) should be used .... if the OEM booster is turned off, the Jack will not perform well .... when the coax is unscrewed from the bat wing, all that is required to connect it to a Jack antenna is to screw it onto the fitting provided
Jim
that is not an amplifier, it's a power supply. You cannot simply remove the amplifier from either the Jack or the Batwing, and there is no reason one cannot use the Batwing power supply on the Jack. But in the end the flat best performing antenna IS the batwing.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
tegu69
Thanks, I think if I had a bat wing it would still be there. The fixed frisbie type had the coax coming up through the base and the coax was hidden. I didn't want to have to drill another hole in the roof.
B_O__Plenty
I replaced my Batwing with a Jack. Simple bolt on and connect the coax. Nothing else. This thing really works and best of all it doesn't rattle all night in the wind and keep me awake! If you are having problems just give the manufacturer King Controls, a call. They have great customer service..
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
JEBar
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
tegu69
I just tossed my Jensen fixed antenna in the garbage today and I'm trying to install the Jack. Can anyone tell me if you have to run the coax outside the base, or can you cover it. The instructions are not to clear on this.
remdog_1
TV is working OK, have cable hooked up right now and TV is working fine. I think I may need a roof visit to check for damage
RoyB
The first thing I would do is eliminate the possibilities of what is at fault TV or ANTENNA.
Can you run in a cable from somewhere and first prove the TV is OK. If the TV works then start troubleshooting the JACK ANTENNA,
The JACK ANTENNA does a pre-amp in its base and they do go bad...
I would think the first thing would be to prove to yourself what the problem is.
Just my thoughts...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
