โApr-28-2017 04:34 PM
โMay-07-2017 05:02 PM
bfast54 wrote:fj12ryder wrote:alexleblanc wrote:Unless you go out and throw some salt on them or run them on salted roads frequently, corrosion shouldn't be a problem. There will be some surface rust but that will disappear with the first usage. Simply sitting for the winter should cause no issues.
I would consider the upgrade, but I fear having my unit sit all winter that the discs would need to be turned about every year due to massive corrosion during the winter. Probably an amazing upgrade for folks who winter in the south or full time though.
Our car sits more often than it gets driven, and has cast iron rotors. Corrosion is not an issue.
Exactly--- so when you park your car for a while do you tear the disc brakes off and put drum brakes on it then huh?????
I just did the install myself I got the parts from Ron and I have not pulled it yet --but I'm definitely looking for the difference in the breaking --stopping power !!!!
Ron was fantastic-- I did the install myself as said --any questions he was right there with the answer!!!!!!
As far as having mor-ryde do the install --disc brakes installed is about$ 3000 and the independent suspension install by mor-ryde is about $5000
I have taken a couple trucks down to the frame and rebuilt them --so I was pretty confident on the install .
The disc brakes for Ron to install that..... it's $1,000 for installation
Definetly way to go as far as I am concerned.
And he does have installers who travel around the country so if you buy a trailer that doesn't have the disc brakes Ron can set you up.
โMay-07-2017 03:47 PM
silverback31b2 wrote:
Hi- it was not a kit, Joy Ryder makes a kit that is kind of pricey. I used Monroe gas shocks, welded mounts to the axles and a cross member welded to the middle tandem spring mount helped to stiffen the frame and provided the upper location to mount the shocks. I have photos, sketches and part numbers if you would like to PM me I'll send. Thanks.
โMay-07-2017 03:38 PM
โMay-07-2017 09:20 AM
I did the disc brake upgrade two years ago, they are awesome and would not own another fiver without them. Got a kit on a pallet from Bill at http://stopyourtrailer.com he is great and top notch customer service.
Just finished adding gas shocks and would recommend them also, installed at the correct angle unlike some factory installs. We just got back from a 2,700 mile round trip to Fort Wilderness Campgound at Disney and the ride was much improved.
โMay-01-2017 07:53 PM
Rally's attended so far-21
โMay-01-2017 07:41 PM
โMay-01-2017 06:49 PM
โMay-01-2017 04:52 AM
โApr-30-2017 06:31 PM
โApr-29-2017 01:13 PM
Bob Vaughn wrote:
I will never have another RV that does not have disc brakes. A couple of deals for a new 5th wheel were squashed because the dealer would not install disc brakes....
โApr-29-2017 12:57 PM
โApr-29-2017 04:25 AM
2naEagle wrote:
Glad to hear that. Performance Trailer Braking is doing mine next week.
Now I'm trying to talk myself into the MORride IS.
โApr-28-2017 06:25 PM
โApr-28-2017 06:20 PM
