โMar-05-2016 02:22 PM
โMar-11-2016 02:11 AM
laknox wrote:
Not sure this would work for this situation, but some people "burp" their fridge by pulling it out, and turning it upside down for a while, then trying it again. Most seem to report (or so I've read here) that this will work...for a while. "A while" being from weeks to years. YMMV...
Something else to try, if you can, and that's to move the thermistor on the cooling fin it's attached to force a lower temp. Don't ask me which way it needs to move, I can't remember.
Lyle
โMar-09-2016 10:03 AM
โMar-09-2016 09:46 AM
โMar-08-2016 10:25 AM
sgreene_1963 wrote:
Thank you for your feedback on this issue. I will try the suggestion with the termistor just to rule this out as a possibility but believe you're correct on the clogged cooling unit. It is ironic that the refer has been at the dealership (service) since mid-February and still not failed. It did the same thing last fall when I had it there then for them to diagnose the issue.
โMar-08-2016 04:21 AM
โMar-06-2016 12:11 AM
โMar-05-2016 02:47 PM
