Electric Brake Problem
remdog_1
Just returned from trip, stopped over last night and left truck hooked up to fiver. I also left 7 pin plugged in and then hooked up to campground electric. When I left this morning, the electric brakes were locked up. Did leaving it plugged in to truck cause a problem? I attempted to back off on juice to brake controller but it did not seem to help, had to stop every 5 miles or so to let brakes on camper cool off, if I continued it would cause smoke coming off brakes. I was able to get home OK, but any suggestions what to check first. Camper is Brookstone 345SA, using Tekonsha Primus brake controller. Ford F-250 Super Duty
11 REPLIES 11
Roger10378
The fact that you were able to pull the trailer 5 miles at a time before cooling the brakes tells me that they needed adjustment even before you had this problem. You probably need a complete brake job now.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
KD4UPL
I suspect you trashed your brakes. I would have them thoroughly checked.
Leaving the 7-pin in while the RV is hooked to shore power is fine. In fact, if you have a GM truck or other vehicle where the 7 pin is hot all the time it will help to keep the tow vehicle battery charged up while sitting in camp for days and days.
Swamp_Man
I would have not only the brakes checked, but the wheels and wheel bearings. The heat build up goes to the bearings and the wheels/tires. I am surprised that since you saw smoke at one point that the tires are not damaged. You are lucky indeed.
Steve & Trudy Jackson
2018 Cyclone 4005
2016 Ford F-450 6.7 PSD
AirSafe 25K hitch
raygreg
Depending on the truck: Leaving the 7 pin plugged in and hooking up to 120 volt campground power can send the 14.2 or so voltage that your converter is putting out to your tow vehicles battery. Most likely will not damage it, but I try to remember to disconnect it just in case.
Vulcaneer
You may have worn your brakes out. Driving with brakes dragging hard, but wheels turning, can cause big problems. If not worn, then glazed. Drums warped, etc. And if your magnets were getting 12V for a long period of time, could have damaged the magnets.
Before I towed it again, I would have the brake system checked very closely.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
remdog_1
Thanks very much Romore, I will remember this for awhile, had a brain fart.. I think before next trip I will still check brake linings and adjustments.
romore
Glad to hear the solution was that simple.:B Leaving the 7 pin hooked up won't hurt a thing.
remdog_1
While I am at it, is leaving 7 pin plugged in OK while hooked up to electric at campground?
remdog_1
I thought about un-plugging, did not think about the tape. This forum is great, I just went and checked my breakaway and it was loose. This dummy didn't think about the breakaway. I plugged it all the way back in and I heard the magnet release. Thanks very much for the information
romore
You didn't accidentally pull the break away pin?
Water-Bug
Are the brakes locked up when the 7 pin is unplugged? If so, it is the breakaway brake switch. If only driving a short distance home, I would have taped off the brake pin on the 7 pin, leaving lights enabled but not brakes.
EDIT. If it is the breakaway switch, taping off the brake pin on the 7 pin would do nothing. In that case, you'd have to dissconnect the trailer battery and the 12 VDC pin on the 7 pin.
