Aug-28-2016 06:19 AM
Aug-31-2016 02:06 PM
tarheel2 wrote:
I have a new 2016 Chev CC Long Bed Duramax DRW 4WD. I am having trouble deciding which hitch to purchase. I am thinking of purchasing a DRV Mobile Suite 38RSSA with washer & dryer and generator. It has an allowable gross weight of 19,000lbs & maybe 5,000 lbs of pin weight. I was leaning towards the B&W Companion until I read about failures on another forum. It is rated for 20,000 gross weight and 5,000 pin weight. Even the trail saver TS3 is rated for 5,000 pin weight and pricey. I need a hitch that will give a good ride, preferably 25,000 lb. gross weight. Any suggestions?
Aug-31-2016 01:49 PM
laknox wrote:lolfj12ryder wrote:
The B&W is made in Kansas. I think we can consider that US made.
But that's where the gateway to Oz is, so you never know. 🙂
Lyle
Aug-31-2016 01:36 PM
Aug-31-2016 01:28 PM
Cummins12V98 wrote:You don't need to convince me the B&W's appear to be a quality product. I already agreed with you on that point.
Inlaws RAM/CURT hitch in his LongHorn dually. He wishes he had the B&W but his came with the truck.
4 bolts of questionable grade holding the head to the base with the Curt and B&W has 8 grade 8. That right there is a HUGE difference.
Both hitches rated to 6,250# pin and 25K towing.
Not too hard to see what system is stronger.
Test? You mean like Andersen's "crush test video" ? That really proved a lot.....same hitch under hard braking alone caused the tubes to bend.
Also US Made VS China Made.
Aug-31-2016 01:18 PM
SoCalDesertRider wrote:
All of B&W's products are US made, that I'm aware of.
So far, everything I've bought from Curt has been US made too.
I prefer to do business with both Curt and B&W, rather than Reese, Draw-Tite, Hidden Hitch, Fulton, Tow Power, and all the other companies that operate under that corporate umbrella, since most of their stuff is made in China, and doesn't cost any less than the American made products of Curt and B&W.
Aug-31-2016 01:04 PM
Aug-31-2016 10:08 AM
Aug-31-2016 08:24 AM
Aug-31-2016 07:14 AM
WTP-GC wrote:
Snip...
US made vs. China made? Please clarify which is which. The Andersen is US Made.
Aug-31-2016 07:07 AM
Aug-31-2016 06:55 AM
Aug-31-2016 05:56 AM
otrfun wrote:Cummins12V98 wrote:Agree, every B&W product I've seen appears to be strong, well-built. If B&W made a hitch that adjusted lower than 16" I'd probably have one in my truck right now.
. . . they said "we test to the weakest component". Anyone with eyes can see the 20K B&W puck hitch for the Ford and GM's is built at least as strong and no doubt stronger than anything REESE or CURT has to offer that "rates" higher.
B&W is VERY Conservative in their ratings. That is why if I were the poster above I would have bought the B&W for his Ford and towed his DRV even if it weighed 21K.
However, on the flipside, heft/weight, nice finish, great welds, and supposedly conservative ratings, by themselves, don't necessarily prove any specific realworld capability. To really prove anything, independent, stress testing would be helpful.
Would be nice if there was comparative test results available for B&W, Curt, Reese, and other hitches. Not just an "ease of use" or "gives the appearance of longevity and strength" test, but a no-holds barred, stress to the point of failure test---using some kind of (hydraulic??) test jig to simulate use with each of the Big 3 trucks (with static and dynamic loading).
Aug-31-2016 05:49 AM
Aug-31-2016 04:15 AM
Aug-30-2016 07:35 PM
