Fifth Wheel Hitch Decision
tarheel2
I have a new 2016 Chev CC Long Bed Duramax DRW 4WD. I am having trouble deciding which hitch to purchase. I am thinking of purchasing a DRV Mobile Suite 38RSSA with washer & dryer and generator. It has an allowable gross weight of 19,000lbs & maybe 5,000 lbs of pin weight. I was leaning towards the B&W Companion until I read about failures on another forum. It is rated for 20,000 gross weight and 5,000 pin weight. Even the trail saver TS3 is rated for 5,000 pin weight and pricey. I need a hitch that will give a good ride, preferably 25,000 lb. gross weight. Any suggestions?
62 REPLIES 62
ken_burke
Well, I would do the numbers very carefully!! We full-time in a Cedar Creek 37 foot 5th wheel. Our 5th wheel is 15,000 pounds. It is very close to being overweight. The pin weight is 3,000 pounds. Our 350 diesel Ford is not overweight, nor is the gross combined weight. Your 5th wheel will be 4,000 pounds heaver than our 5th wheel.
What will happen when you try to stop that load??
I would suggest looking at a 450 diesel.
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
fj12ryder
laknox wrote:
fj12ryder wrote:
The B&W is made in Kansas. I think we can consider that US made.
But that's where the gateway to Oz is, so you never know. 🙂
Lyle
lol
Howard and Peggy
"Don't Panic"
Cummins12V98
"Why does he wish to have the B & W over the Curt?"
Because it has to be "just right" to get it to latch properly. I hitched it twice and he is right.
"You call those 4 bolts "questionable", so you don't know the grade, therefore how does that make a "HUGE" difference? Can't bolts be replaced fairly inexpensively? "
There is a definite marking on the head of a bolt that has a "8 grade". See pic below. CURT's don't look like that.
"How does one know that B & W didn't procure their bolts from the same factory in China that Curt did, just paid more for the head stamp?"
Because they have a 100 percent Made In USA product, call and ask them.
"I have a hard time seeing which one is stronger. They are both engineered the same, but someone is supposed to make the decision based upon visual appearance?"
You don't think 8 blots are stronger than two? You don't think the BV&W base is a MUCH stronger design?
"The crush test is valid. Anyone with an understanding of how physics are applied to such equipment with angular supports knows the legitimacy of such a test. In fact, the crush test exerts more pressure on the supports than any 5er on the market."
The Crush test they tout did not show the weakness from hard braking.
"The entire internet world is aware of one Andersen UH hitch that failed with bent tubes. A more limited viewing audience (this forum) is now aware of one B & W Companion that failed. Score is tied. Move along."
I can guarantee you no one re designs a product from one issue. The world is larger than RV.NET.
"US made vs. China made? Please clarify which is which. The Andersen is US Made."
As said Kansas, USA. The people that did not lay off their employees when the big downturn in the rV industry hit. The owner paid his employees to do community projects.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
otrfun
Cummins12V98 wrote:
Inlaws RAM/CURT hitch in his LongHorn dually. He wishes he had the B&W but his came with the truck.
4 bolts of questionable grade holding the head to the base with the Curt and B&W has 8 grade 8. That right there is a HUGE difference.
Both hitches rated to 6,250# pin and 25K towing.
Not too hard to see what system is stronger.
Test? You mean like Andersen's "crush test video" ? That really proved a lot.....same hitch under hard braking alone caused the tubes to bend.
Also US Made VS China Made.
You don't need to convince me the B&W's appear to be a quality product. I already agreed with you on that point.
I believe you missed my point. Appearance of quality (or lack thereof), to include the use or non-use of grade 8 bolts, in itself says nothing about a hitch's ACTUAL ability to safely carry a given amount of weight. For all we know, a mechanical engineer might tell us a grade 8 bolt is overkill for this particular application. On the flipside, the marketing department may have recommended a grade 8 bolt---just to give the added appearance of quality and strength---even though their ME said it's overkill . . . again, who knows.
Again, the only way to prove or disprove the superiority of any given hitch is to test it to see if it safely carries/supports it's rated weight. Ideally, take it a step farther, and stress the hitch to the point of failure to see how conservatively (or not) a given hitch is rated.
Bottom line, I believe B&W are well-made hitches with clean lines, good welds, grade 8 bolts(?) . . . that exude a massive, strong look . . . plus, they are, Made in the USA. However, can anyone use the previous sentence to prove it will out-carry a competitor's hitch. Nope. Can a good marketing department use this same sentence as part of an effective marketing campaign? Absolutely! Would I consider purchasing a B&W? Yes . . . if they made one that would adjust lower than 16" 🙂
Cummins12V98
SoCalDesertRider wrote:
All of B&W's products are US made, that I'm aware of.
So far, everything I've bought from Curt has been US made too.
I prefer to do business with both Curt and B&W, rather than Reese, Draw-Tite, Hidden Hitch, Fulton, Tow Power, and all the other companies that operate under that corporate umbrella, since most of their stuff is made in China, and doesn't cost any less than the American made products of Curt and B&W.
I too will buy CURT but NOT there 5er hitches as they are ALL Made in China.
Me_Again
Only Curt's receiver hitches are still made in the USA. The 5th wheel hitches are all made in china. Call them like I did and they are confirm it to you like they did for me. Our son is a Curt wholesaler and I could have gotten a really good price on one. However I got down to Hijacker and B&W. Went with B&W on a Demco picture frame.
Chris
laknox
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
SoCalDesertRid1
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
BarneyS
WTP-GC wrote:
Snip...
I will clarify it for you. He was not talking about the Andersen. He was referring to the Curt vs the B&W.
I agree with your previous comment - "move along"
Barney
Not towing now.
fj12ryder
Howard and Peggy
"Don't Panic"
WTP-GC
Duramax + Grand Design 5er + B & W Companion
SBGTF
Cummins12V98
otrfun wrote:
Cummins12V98 wrote:
. . . they said "we test to the weakest component". Anyone with eyes can see the 20K B&W puck hitch for the Ford and GM's is built at least as strong and no doubt stronger than anything REESE or CURT has to offer that "rates" higher.
B&W is VERY Conservative in their ratings. That is why if I were the poster above I would have bought the B&W for his Ford and towed his DRV even if it weighed 21K.
Agree, every B&W product I've seen appears to be strong, well-built. If B&W made a hitch that adjusted lower than 16" I'd probably have one in my truck right now.
However, on the flipside, heft/weight, nice finish, great welds, and supposedly conservative ratings, by themselves, don't necessarily prove any specific realworld capability. To really prove anything, independent, stress testing would be helpful.
Would be nice if there was comparative test results available for B&W, Curt, Reese, and other hitches. Not just an "ease of use" or "gives the appearance of longevity and strength" test, but a no-holds barred, stress to the point of failure test---using some kind of (hydraulic??) test jig to simulate use with each of the Big 3 trucks (with static and dynamic loading).
RustyJC
Unfortunately, each brand of truck uses their own unique puck footprint pattern.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
tinner12002
Just a courious question, does GM use the Ford or Ram puck pattern or do they have their own?
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
timmag
Anderson ultimate and Love it.
