Nov-28-2014 06:59 PM
Nov-29-2014 09:41 PM
Nov-29-2014 08:53 PM
Nov-29-2014 08:52 PM
Nov-29-2014 08:19 AM
Nov-29-2014 07:50 AM
Nov-29-2014 07:30 AM
therink wrote:
You said you have the 6.0 gasser. Is your axle ratio 4:10 or 3:73? If 3:73, the max trailer weight you can tow is something like 9600 loaded. If 4:10 it jumps to around 13,600.
The loaded pin on that fiver is going to be around 2600 lbs. Add 150 for hitch, 500 for passengers and gear and you are going to be over the gvwr of the truck. Anything else in the bed of the truck, tools, firewood, etc will put you way over gvwr.
Lots of people tow heavy fivers with 3/4 trucks but I would consider a lighter fiver or a 1 ton truck.
I have been in this boat and was not comfortable towing over weight so I moved to a one ton. I now have room to spare.
Nov-29-2014 07:16 AM
FastEagle wrote:
It’s probably best to load up the trailer as it would be loaded for a camping trip and then find some scales for a more accurate pin weight until you become familiar with your trailers balance when loaded.
Nov-29-2014 07:08 AM
donn0128 wrote:das wrote:
Thanks for the info and ideas. That's what I was hoping to hear was someone that tows with a similar truck and trailer. Larger TV isn't an option for me since I just got this on 3 months ago. Any lighter fifth wheel ideas are welcome if I could find something similar (just lighter). I know that I cant have everything that we wont wrapped up in a small trailer. Other option is a travel trailer that almost has the same set up. A Keystone 34BHPR that only has a dry weight of 7076 lbs.
Why do you keep asking about "dry" weights? Have you been reading the posts?
But to answer your question, yes a TT would be a far better choice for your truck. With the 6.0L motor you also have to be very careful of weights.
Nov-29-2014 06:35 AM
Nov-29-2014 06:32 AM
Nov-29-2014 06:15 AM
Nov-29-2014 04:52 AM
byronlj wrote:You will also have mounting rails and brackets..It's not like 60# will make a huge difference if you're over on the weight.
How come everybody says to add 200# for a hitch? I just looked up the shipping weight for a couple of large hitches, 18 and 20k, and they only weighed 143#. Maybe they are adding 60# of paint to cover the mounting bolts.
Dave
Nov-29-2014 04:43 AM
Nov-29-2014 04:31 AM
