Fresh water tank drain too slow
dogvetia
I have a 2018 cruiser aire. It has a 1/2 inch plex pipe out the bottom to drain fresh water tank. It takes several hours to drain the tank. Would like to sanitize my water system but drains so slow. My motorhome would dump 100 gals in 3 minutes but had much larger slide vale as a dump. Am I doing something wrong to have to wait several hours to drain??
2012 F350 diesel
2018 cruiser lite 28rd
12 REPLIES 12
C_Schomer
See if you have an access cover under the plumbing area. Mine has one and it isn't very hard to fix those kind of things. My water drain was already done with 1/2" IPS but the opening in the tank was choked down. The right size drill bit quickly fixed that. Craig
dogvetia
Thank you all for your suggestions!!!!
2012 F350 diesel
dogvetia
Mt Bob. That's what I thought I would do also. Thanks for all your suggestions s. Tom
2012 F350 diesel
MT_BOB
I agree, probably restriction in the line, not a rare situation , builders leave garbage in tanks quite a bit. I would try blowing air into the drain,then see if it makes a difference, even for a bit, next time. You could call builder and find proper procedure to gain access.
TXiceman
For draining the freshwater tank, I just open the gravity fill and the small dump line and let it drain overnight.
Kwne
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Cummins12V98
I have the 100G fresh and it does tale a long time to drain as mentioned it has a 1/2" pex but I guarantee the 1/4 turn valve has an even smaller opening.
No biggie to me as I simply open the valve and when it's done draining I close it. There is a vent hole on my Andersen valve assembly like most any other RV that allows plenty of air into the tank for draining.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
IMO, you probably have trash in the line. I have nearly 60 gal fresh, with the 1/2" drain line, and it takes about 30 minutes to dump a full tank. I wish it had a 1.25" line like my old Komfort did.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
dogvetia
This has the cold weather package which stops all access to the tanks. Also there is no gravity fill just a hose connection. Thanks for ideas. Best may be run thru get. 60gal tank
2012 F350 diesel
enblethen
I take the adapter pipe fitting out of the tank. That increases the opening. Originally had debris from factory drilling the tank lodged in opening.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Lwiddis
I agree…run the pump. With a bucket in the kitchen sink and a three pound coffee can in the bathroom it’ll drain quickly.
2oldman
Run the pump, open the faucets and go out the gray tank.
sch911
Open the gravity fill cap and see if that helps.
OEM Auto Engineer- Embedded Software Team
