Fuel station hose
allcool
Anybody else have the very stiff fuel station hose, first use of the year, till its used a few times beginning of the season.
It then seems to get flexible again, till next year again, then it gets very stiff and not very bendable after summer storage. But run some fuel thru it a few times and it seems to get its flexibility back..?
What going on with my hose..?
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
F350 CC 6.7PS Platinum
9 REPLIES 9
allcool
Thanks for the replies guys...
The hose is fine now that fuel has been run thru it a few times. Very supple again and no leaks at swivel fitting.
This stiff hose syndrome has nothing to do with hose still full of fuel.
Its so stiff first time of the season scared it will split in two or crack. And the swivel fitting leaks like a sieve first couple times at the start of the season...
My TH sits all summer long till dune season starts in Oct. So 6 months with no use, no fuel in hose and swivel orings. Not sure why it reacts with a very very stiff hose and leaking handle till the fuel softens it up again.
Just did a week at the dunes and hose/handle/swivel is fine once again. Nice and soft and supple, leak stopped 100% at the handle swivel fitting also.
This stiff hose leaky handle has happened every year, beginning of the season.I've owned this TH since 2010 iirr. Just thought others might have have a solution to this...
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
christopherglen
After fueling something I put the nozzle in the trailers tank, lift the hose up and (with the pump off) squeeze the nozzle. Fuel pours out and air goes into the hose. Coiling goes easy after that.
Anyone added a filter or water separator to the hose?
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Dirtclods
Shutting the pump off and releasing the fuel left in the hose, helps with re-coiling it. 2nd that!
I'll add that when I'm done using my fuel I shut the pump off angle the hose and nozzle towards the ground and release what's left into a can for my fire starter.
AAA Motorcycle RV Plus
coolbreeze01
I went with a 10' hose and a swivel at the nozzle. Wish the hose/pump compartment was larger.
2014 Sandsport 26FBSL
arhayes
momentum rv wrote:
Mine was fairly stiff and hard to work with. I wanted to add a swivel at the nozzle to help with the difficulty using it and ended up with a whole new hose (14ft and much more flexible) and a swivel. Got them both at Tractor Supply ($60 I think.)
The extra length allows me to fuel toys behind the rig instead of having to be sure I have room on the back side. The more flexible hose and swivel at the nozzle make it much easier to use.
Great idea on the longer hose! 😉
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Strabo
We never use ours cause it never works right anyways.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
momentum_rv
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
arhayes
I've not had that issue so far. I don't use the fuel statio a lot, and we full-time, but it has been flexible every time I've used it. It's 45 degrees here now and I just filled up the bike and it was fine.
Alan and Kathleen
CarlT100
Mine is the same way.
Carl S
US Army Retired
'11 F-450, 6.7, 4X4, crewcab; '14 Fuzion Impact toyhauler
'12 Triumph Tiger 800XC; '03 Triumph Bonneville T100, 1968 Triumph TR6 Trophy 650cc
SWMBO: '13 HD Sportster; '06 Honda Big Ruckus
