need window screen
bbaker2001
purchased a 2001 28 RKB
the screen in bedroom slide is missing
also have 2 Emergency windows that have no screens. can I find them anywhere
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
4 REPLIES 4
missourijan
Check with the rv salvage companies like Colaw in MO. There are several around the country.
bbaker2001
yes, my TT has a screen like yours. my 5er has the double latch at bottom. we are looking at making something.
DW has us remodeling the 5th now. it looks so good almost done. have got rid of all the dated pink. changed all window coverings, more and more
could not have done it without this site
BB from California
2015 Ram 3500
2001 Cardinal
JohnG3
Met a couple in a campground that had a 5th wheel similar to ours. Their bedroom emergency exit window does not have a screen and ours does. We checked the difference and I found that our window emergency opening lever is on the bottom of the window frame and the window can be propped open without interfering with screen. The other's window and screen have levers on both sides that are mounted in the window frame where the screen would live.
You may be able to make a screen and mount it on the inside of the frame but that would entail removing the screen and replacing it whenever you wanted to open and close the windows.
John and Elaine. Furry ones, Bubba, Buddy, Barney and Miss Chevious
2017 Tiffin Allegro Bus 40 SP
Know guns, know safety, know peace. No guns, no safety, no peace.
agesilaus
Assuming these are standard window screens you can go to any big box hardware store (Lowes ect) and buy a kit to make the window screen. Not hard to do if you are minimally handy. If you don't want to make one you should just ask them where you can get one made. They'll probably know, you'll need the exact measurements from the window.
How to make one
Frame Kit
And you'll need a roll of fiberglass screen to finish the job
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
