Generac will not start / smell of gas
Goldneye1
Over the weekend I ran the Generator for about 2 hours all of a sudden it just quiet like it ran out of fuel has 1/4 tank in it. Tried to restart over and over and started to get a strong gas smell (seems like the carb is flooded). I let it set over night and still nothing. Any help would be great. Model # 4700-0
Sorry mods I original posted this in the Class A forum.
28 REPLIES 28
Strabo
Goldneye1 wrote:
it took me a bit longer to get back but here it is. I got it started after putting 5 gal of gas in it and bringing it up past the 1/4 tank mark.
Thank you all for the help.
See i was right, good job!!
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
Goldneye1
Goldneye1
arhayes wrote:
Check oil first. Should have a low oil sensor. Mt Onan flashes error codes... Have you checked the generac manual for something similar?
Oil level is good, I glanced over the manual i'll take another look at it.
Goldneye1
BigDogF250 wrote:
nayther wrote:
midnightsadie wrote:
if your main fuel tank is at a quarter of a tank the gen set will not run ,safety feature.
motorhomes yes, trailers no.
Every absolute statement has an exception. :B
My trailer uses a single fuel tank, the generator can't draw below 1/4 tank. The fuel station can draw to empty.
I'll dump in 4 gallons to get it off that 1/4 mark and see what happens makes sense to me.
Goldneye1
Toddupton wrote:
Does it have an oil sensor?
I believe it does right around the oil filter.
BigDogF250
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
nayther
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
arhayes
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Jerrybo66
I would start with the cheapest possible fix. A new plug. They don't fail often but they do fail just the way you said it stopped. I always carry a spare for any small motor I have.. Good luck.
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
midnightsadie
Strabo
I bet its out of fuel.....
AJBert
Check the easy stuff first. Remember, you only need three things to get combustion.
Air - already been mentioned
Fuel - check
Spark - first check to make sure the boot didn't come off the plug. If not, check for spark
I had the magneto go out on my generator in less than a year. Hopefully that's not your problem.
If you have spark, spray some starting fluid through the carb. If it starts time to rebuild the carb. If it doesn't start and you have spark...ummm...probably time to bring it into the shop, unless you have knowledge of tearing down small engines.
Vulcan_Rider
There are various kinds of toy haulers; is yours a 5th wheel ?
Check the air filter/intake to be sure it hasn't tried to ingest a piece of paper or plastic......or the air filter itself.
Toddupton
