โAug-19-2015 08:04 AM
โAug-23-2015 08:26 AM
โAug-23-2015 06:46 AM
Mile High wrote:mgpassport wrote:
Thanks for the reply's, I was just curious.
I just thought that FW that cost around $50.000 should come with one like a MH.
Sometimes I think to much....LOL
With that, I wouldn't look at a 5th wheel without the generator prep package at least. It's a pain in the keester to install a generator without the prep if you decide later. The prep should come with a heat shield, transfer switch, and a remote switch to start from inside.
โAug-23-2015 06:44 AM
Mile High wrote:laknox wrote:
Another thing to consider, is that the Onans are all straight generators, meaning that they run at idle with no load, or they run wide open with even the smallest load.
Lyle
Did Onan change something? Mine runs at a fixed throttle whether under load or not.
โAug-23-2015 06:20 AM
โAug-23-2015 06:14 AM
Lyle
โAug-23-2015 05:56 AM
dapperdan wrote:
Hey Rusty did DRV put that outlet on your trailer or did you do it yourself? Just curious, we have the same trailer as you, with the gen prep.
Sorry for hi jacking this thread, sorry. ๐
Dan
โAug-23-2015 05:49 AM
RustyJC wrote:sdetweil wrote:
I converted my Onan to Propane, as I didn't want to carry gas. We pulled into Little Rock, two weeks ago at 96degrees (feels like 102), after towing all day with outside temps over 105. I started the gen and the A/C as we waited to register, pull to our site and setup. turned it off after I connected shore power, and the ATS switched back.
Also started it at a rest stop to heat some stuff in the microwave for lunch.
can't do that very easily with a portable.
Actually, our 5th wheel has a generator prep with a 50 amp twist-lock Marinco receptacle on the front of the 5th wheel. We carry 2 Yamaha EF2000iS generators (paralleled) in the back of the truck that are connected to the 5th wheel via a 30 amp cord. We can run the Yamahas going down the road to pre-cool the 5th wheel, run the microwave, etc.
Rusty
โAug-23-2015 05:47 AM
โAug-23-2015 05:22 AM
โAug-23-2015 04:10 AM
ford-willy wrote:
Most inboard generators in 5th wheels run on propane. Very impractical and a pain to keep up on filling your propane bottles constantly. I believe only toy haulers come with gasoline operated gens. Like others I just carry two 2000 Super quiet Hondas. One must be a "companion" 2000 Honda. If your not needing much power just run one. If you need to run an air conditioner or use the microwave run both by using a simple parallel wire connector kit and you have a 4000 watt output.
โAug-22-2015 08:01 PM
โAug-22-2015 08:46 AM
TGPILOT wrote:MPI_Mallard wrote:
I carry a Honda 3000 on a rack on the rear of my fiver, why I like having a separate genny is being able to use it for other purposes also maintenece and repairs are easily done and a comparable genny like an onan would cost a lot more and chew up the space in the forward storage bay. Also as they are usually mounted in the front storage bay migrating exhaust fumes would concern me opposed to mine that easily vents out into open air on the rear racksomething to consider!
Red Green;
Remember, If it moves and it shouldn't, duck-tape,
if doesn't move and it should,WD40!!
That looks like a single receiver input and not a double. How does it hold up and what did it cost to have the thing installed? I tried a new EU3000IS, only ran it about fifteen minutes only to find that it kept going into overload.
I kept reducing the load, didn't help, so I bought a 5000IS and right now it's in the back of my truck between the tool box and the hitch. So far, I've only had a chance to run it one night and it ran everything in a Pilot parking lot and ran about 12 hours on one tank.
โAug-22-2015 06:19 AM
โAug-20-2015 10:42 AM
โAug-20-2015 10:23 AM
