Going from travel trailer to fifth wheel soon
noonoo11
Would like to move to a fifth wheel. My tow vehicle is 2010 sierra 1500 engine 5.3 with tow package. I see there are alot fifth wheels out there that I can tow. Thinking of a Keystone cougar lite.
14 REPLIES 14
TXiceman
As advised, carefully check your available pin load capacity based on the real weight of your truck ready to camp.You will find that a 1/2 ton truck will be limited by the rear axle GAWR and GVWR. A 5er will impose a higher pin weight that will the hitch weight of a travel trailer. So your limiting capacity will be the trucks true payload capacity ( that is what is left over once you load cargo and passengers in the truck).
Practically speaking, most 1/2 ton trucks will max out on pin weight with about a 24' 5er.
DO NOT listen to the Rv sales person. They seldom understand tow ratings and limits. A 1/2 ton towable trailer will only be OK if you tow the trailer empty and never have more than yourself in the truck.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Mootpoint
I did some calculation for my BL and found he was fine with his 30' plus TT but would have to go to about 28' in a 5'er he could handle. Better floor plan selection and more area with the TT so that's what he stayed with. He has the same TV as you.
It was the tongue weight that killed it.
Nothing sucks more than that moment during an argument when you realize you're wrong.
goducks10
Jack_Diane_Freedom wrote:
Make sure you pick one with lots of storage as you will lose the use of your truck bed for transporting your camping equipment. When deciding on which 5er make sure you allow for the heavy weight of the 5er hitch.
The Anderson Ultimate only weighs 40lbs.
He'll still have the room in front of the hitch. I have 45" of room and very rarely use all of it as my 5'er holds most everything we take. And he won't have to pack and unpack the stuff out of is truck as most can just stay in the 5'er. Really a moot issue.
goducks10
http://www.palominorv.com/ProductInfo.aspx?model=puma&page=floorplandetails&floorplanid=3945&RVType=...
This has about a low as dry pin as I've seen. Look at your trucks payload sticker and see how that matches up with the dry pin. You can get an Anderson 5th hitch that only weighs 60lbs, that will help keep weights low. Problem with 1/2 tons and 5'ers is the higher pin weights vs lower tongue weights of TT's. JMHO but you get more TT for the money than 5'er as a general rule. You can also tow a bigger trailer when going to a TT. Not sure what the fascination is with wanting a 5'er when having a 1/2 ton. It seems like you give up extra living space that you could have if going with a TT over a 5'er. If it's a matter of a shorter unit for camping then that's understandable.
With that being said I would rather seen someone with a 1/2 ton tow a 5'er at max load vs a TT at max load. 5'ers just tow so much easier.
Could the OP post his trucks ratings?
oweninthekeys
Old-Biscuit wrote:
Load your truck up ready to go camping.......all passengers, and stuff in cab, full tank...and go get weighed.
Weigh ticket will give you Front axle weight, Rear axle weight and trucks total weight.
Compare to YOUR trucks FAWR, RAWR, GVWR and Rear tire max load ratings......then you will know how much weight you can 'Carry' as in 5vrs pin weight (Don't forget the 200# of hitch weight that will be in truck)
Look at the trailers you are interested in......take 20% of their GVWR to use as a guesstimate of pin weight.
Can you 'carry' that weight without exceeding RAWR, Rear Tire MAX Load Ratings and Trucks GVWR???
Words could not of been said better.
USAF Retired 2000
DOD Civilian to Retire 2015
2014 Dodge Ram 2500 6.4L Hemi
Andersen Ultimate Fifth Wheel Adapter Hitch
2014 Winnebago Lite Five FW30RES
Old-Biscuit
rugermark2
I am not saying not to buy one but my Cougar Xlite is over 1500 pounds of pin weight. If you look at the smaller Xlite you can find them with 1100 pounds of pin weight. Choose you floor plan wisely.
2011 Ram 2500 6.7 Cummins
2015 Cougar 29RLI
When doing this , better triple check your weights , as you will overload a 1500 a lot sooner with a fifth wheel. It's not what you can pull , or stop....it's what you can carry in the bed , ( tongue weight) that will get you.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
therink
To stay within the gvwr capacity of your 1500 truck, you are likely going to need to find a fifth wheel with a "loaded" pin weight under 1,000 lbs.
I don't think you will find one. Do yourself a favor and consider getting a larger truck.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
DutchmenSport
Cougars are nice campers! Very popular where I live. They must be good for so many to own them. In the area where I live, it seems folks have Cougars parked in their driveways for years (meaning they don't trade them) so they must be happy with them. (That's a good thing!)
Enjoy!
Peg_Leg
Watch the pin weight. Most everything you put in the 5er, adds to the pin weight.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Jack_Diane_Free
Campinfan
You are going to take a beating from many here for even considering it. Follow SWD's advice.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
SWD
Watch your weights carefully.
