May-24-2016 04:59 PM
May-26-2016 06:31 PM
SolidAxleDurango wrote:avvidclif1 wrote:
You do realize that all the reports of bad blowmaxs have been the "E" rated ones run near max.
this is not true
May-26-2016 05:30 PM
May-26-2016 05:07 PM
SabreCanuck wrote:
....snip...
Nope, not at all. But if you typically drive 70 mph down a gravel road, come to a skidding stop, do a rubber-wrenching U-turn to jackknife into a spot.... Let's just say YOUR tires are gonna wear out long before mine.
Blaming everything on the manufacturer is a typical response because it's easier than taking ownership of possibly poor driving habits.
BTW - I forgot to add hauling 1000# over the tire's limit. But, that's for another thread.
May-26-2016 05:01 PM
gmw photos wrote:SabreCanuck wrote:
You can add me to the club of those that think "speed" has something to do with it.. You can also throw in heat, terrain, parked for time, PSI, 90 degree turns, age, curb scuffs, tread wear, etc. that have more to do with blowouts than the mfg.
Moral of the story > Without knowing a WHOLE BUNCH of extra details it is really tough to trust generic internet ramblings about 'china bombs'.
Of course spending more $$ on the better tires will help because you are getting a BETTER TIRE to withhold all of the above. The other option is to just stop doing most of the above and run the stock tires..
....ok, so let's see here, to safely run a ST tire I need to apparently drive slowly only on cool days, on smooth terrain, I can't park the trailer, I must avoid 90 degree turns.....
.....hmmm....yeah, let me think on that a while.....:)
May-26-2016 04:13 PM
Fabguy wrote:gmw photos wrote:
How can I be expected to "watch them carefully" as I am driving down the highway on a hot day in heavy traffic ?
I had no problem doing it.
May-26-2016 03:55 PM
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Pullrite Superglide
Pulling a 2015 Keystone Cougar 280RLS
May-26-2016 03:49 PM
May-26-2016 03:45 PM
Fabguy wrote:
I used Towmax tires on our old Sprinter travel trailer for 6 years, 10,000 miles and didn't have an issue. I visually inspected them every time I checked them for air and once I started noticing ply separation on one tire, I replaced them all with Maxis.
I am of the opinion that ALL ST rated tires are of inherently poor construction and need to be watched carefully.
May-26-2016 03:09 PM
May-26-2016 02:35 PM
May-26-2016 01:17 PM
this is not true
Please post the conflicting reports.
May-26-2016 01:11 PM
vr200275 wrote:Racine96 wrote:
Did you hit something? It looks like it was cut. ???
I don't think I hit anything. It's the rear tire so there are two tires in front of it. Seems they would of been damaged also. I was on the interstate going 65mph. It was 5:00 pm traffic and happened so quick its hard to tell.
May-26-2016 12:29 PM
this is not true
May-26-2016 11:54 AM
larry barnhart wrote:I have had GY marathons on 4 different RV's and never had a issue. I know others have had issues with them.
Is the good year Marathon a cheap tire. Just a question?
chevman
