โFeb-26-2020 05:16 AM
โFeb-26-2020 06:30 AM
Jeff1953 wrote:schlep1967 wrote:
I wouldn't make a decision either way until you pick out the 5th wheel you are buying. Some 5th wheel frame manufacturers will void the warranty with the use of gooseneck adapters.
Warranty most likely won't be an issue, since we're looking at buying used. My main concern would be safety. Are the adapter inherently not as safe?
โFeb-26-2020 06:29 AM
โFeb-26-2020 06:20 AM
Jeff1953 wrote:
Greetings. We just picked up a 2006 Silverado dually for towing a 5th wheel that we've yet to buy. It has a virgin bed in it, so I have to buy and install a hitch. My question is for people who have had both types. Which do you prefer? I like the idea of a gooseneck, so you have a completely flat bed to haul things, but, you need to buy an adapter for it. It appears to me (being completely inexperienced with 5th wheel trailers) that the 5th wheel hitch would be easier for hookup. However, I'm guessing it's a real bear to get in and out of the truck bed So, before I do either, I thought I'd check with the experts. Thanks.
โFeb-26-2020 06:02 AM
โFeb-26-2020 06:01 AM
โFeb-26-2020 05:56 AM
sayoung wrote:
Put one of the underbed rail with turn over gooseball so you have both. Another option is just a turnover ball gooseneck & a B& W Companion that slips into the gooseneck ball shaft.
I use a Curt turnover gooseneck with a Curt X-Rail that mounts in the hole and use a B& W Patriot .
Really depends on how heavy a 5er your planning on. If real heavy look at the Traiersaver Airride hitches but B&W will take some really heavy ones also.
โFeb-26-2020 05:53 AM
โFeb-26-2020 05:39 AM
โFeb-26-2020 05:35 AM
