Grand Design Momentum
kpsutton
We are looking at purchasing the Grand Design 355TH. It has a GVWR of 18,000 lbs. There are only 2 axles at 8000 lbs. I am worried that the GVWR of this rig will be over weight for the 2 axles. Does anyone else have this rig and if so have you seen any issues with this?
Kathy Sutton
:B
8 REPLIES 8
proptwister
We have the 355 and love it.
After 25 years of GM products, I've jumped ship!
14' Ram Laramie Longhorn 3500 High Output Cummins/Aisin Transmission
Factory 5th Prep with B&W Companion Hitch
14' Grand Designs 355TH Toyhauler
5th AirBorne Pinbox
LI_Happy_Camper
I also have a Grand Design Momentum 385th which is longer and heavier than the 355th and have zero problems with dual axles. I have taken a few long trips and I am headed to Tennessee next week and have total confidence in the RV. Grand Design makes a great RV and you won't be disappointed. The customer service is second to none!!!! Good Luck and enjoy your Grand Design. We love ours!!!!!
2014 Grand Design Momentum 385TH
2011 Ford F-350 6.7 Crew Cab DRW Golden Bronze Metallic
Reese 20K fifth wheel hitch
Firestone ride rite airbags
kpsutton
Thanks everyone for the replies.
Kathy Sutton
:B
Big_Mike385
While I do not own the 355, I do own the 385. The weights are right on for the axles with toys and loaded up, with a full tank of water/propane, etc. I took mine over the scales and weights were as follows: Steer Axle: 4,220lbs; Drive Axle: 7,640lbs; Trailer axles: 15,380lbs; Gross: 27,240lbs. Those weights are with full water, loaded with food/clothing etc for two weeks, and a Harley Dresser and a Honda Shadow.
I hope that helps. By the way, it handles better with the toys than without.
Big Mike.
2015 Grand Design Momentum 385TH
2005 Dodge Ram 3500 Dually
2006 Harley FLHTCUI
arhayes
We just bought a 380TH and love it. I have no concern with the axle config, and think 2 axles from a tire wear standpoint may be better than 3. As stated, with the pin weight removed, we're well under the axle rating, so no worries at this point.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
2008Wildcat
The hitch weight is 3400 lbs dry.
Even fully loaded, you will have plenty of GVW left to carry on the 2 axles.
2013 Columbus 320RS
2011 RAM 3500 Outdoorsman SRW 6.7 Cummins- tweaked!
Sandia_Man
Not uncommon since over 20% of rig's GVWR will be pin weight with the rest on the axles. I agree with you that it would be wiser to have axles rated to GVWR of TH for more safety margin, our TH axles exceed GVWR of our TH with stock tires rated to carry the same.
It's the main reason why I was able to get 3 years and 20K miles off of our stock china bomb tires before replacing with Maxxis tires for peace of mind. Just pulled off wheels this past Spring to repack bearings and they still look good after 7 years of heavy use. Happy camping in your Grand Design TH!!!
lawnspecialties
Most toy haulers have a GVWR more than the combined axles.
Remember, some of the weight rests on the pin, too.
