grey water
tadpole54
Hello all,
Have purchased a 2004 Keystone Montana. The sink keeps stopping up. My grey water valve is open. Shouldn't this water go right out? My black tank needs pumped which makes me wonder if this water is going there instead. That would be against normal plumbing setup, right?
34 REPLIES 34
Old-Biscuit
Probably could have had that answer IF you had posted WHICH model of Montana to begin with.....or at least list it in signature
tadpole54
I TT Keystone this morning.
There is not a 3rd valve on this model. They say I simply have a clogged sink and proceed accordingly. Again, just bought and set up the unit so there may have been a problem prior to my discovery. Taking off trap next.
Charlie_D_
Broken off or missing handle? Check for a hole somewhere where it may have been. First trip out on our current rig the handle rod unscrewed and lost it somewhere on the road.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Old-Biscuit
tadpole54 wrote:
Calling the dealer and/or Keystone is the next step. Was hoping there may be a simple solution I was overlooking.
Thanks to all.
SO......
You have looked around the driverside tires/under slide out (in front/between/behind) and found no 1 1/2" drain valve?
Maybe handle has fallen off and there is just a valve stem????
One other place......do you have a 'sewer hose storage compartment' ???
On some Keystone models galley drain valve was in there.
BUT on the Montanas---------driverside wheel area
If would HELP if you posted which actual model
'Signature' is great place for that on-going info as lots of questions/answers are easier when Brand/Model are known
tadpole54
Thanks to all.
Racine96
Does it have three tanks or two and one of them is not draining well? I am not clear.
jffnkrn
Yep, I agree with the tank quantity. check your information panel and see if you have three tanks, then you should have three valves. contact manufacture and get them to help. Good Luck & Be Safe ! ! !
fla-gypsy
You need to find the third tank valve. You may be flooding something
Old-Biscuit
Three tank level monitors Black/grey/galley then 3 drain valves
Galley (kitchen sink) drain valve will be around axles/tires...front/between/behind but in that general vicinity.
And if you have a slide out on that side it makes it tougher to find.
Get down on knees, crawl around and LOOK
Goostoff
My in-laws just bought an 03 Montana. There is a second gray tank the valve is located either between the axles or just in front of the front. I cant remember. You should have a total of 3 handles to open
1993 Chevy C3500
2005 Cedar Creek 34RLTS
grampscamper
I think on some trailers the valve is on the 1-1/2" pipe that drains into the 3" pipe. I would have another close look. It sure sounds like there should be another valve.
You may have to have a closer look near the axles.
2019 Grand Design Reflection 230RL
2020 Ford F250 Lariat CC SB 4X4 6.7 B&W Companion RVK3300
dvitale300
Why don't you call keystone and give them the VIN number. They can look up the build sheet and specs. It might help
BB_TX
Not sure about the 2004 Montanas, but newer ones (2007 in my case) do have two grey water tanks, one for the shower/vanity and one for the kitchen (galley) plus the black water tank. The pull handle for the kitchen may be in front of the wheels, between the wheels, or behind the wheels depending on the Montana model. That water may come out the same outlet as the shower/vanity/black water drain pipe, or it may have a separate drain pipe at the rear of the trailer. My handle is just in front of the wheels and under the bedroom slide.
tadpole54
The kitchen sink is the one that won't drain and is above/behind the axle. I don't see another valve handle besides the black and grey valves at the opposite end of the camper. I do have 3 water gauges to monitor. Grey, black, and galley readings. But only 2 valve handles that I can find.
Bumpyroad
there are units where the bathroom sink drains into the black tank. which sink are you talking about?
bumpy
