HI ALL Newbie to trailer world need help
wheels59
Bought a older but nice toy hauler. Its a 20' hybrid with front pop out type sleeping area. The question, best way to clean mold from canvas/vinyl from that front part, not real bad. Light brown, assuming mold. THANK YOU
PS Was told to stay away from bleach......
6 REPLIES 6
Dirtclods
Oxiclean works real well.
AAA Motorcycle RV Plus
wheels59
THANKS ALL!
arhayes
I used to used a 4:1 water to bleach solution to clean mold my old tent. Just rinse good after. Put it in a spray bottle, spray an area, give it a few minutes then agitate with a brush then rinse. Should get if off.
You just want to make sure for the future that when you get home after a wet camping trip you pop out the canvas area and let it dry out in the sun thoroughly. Mold hates light.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
coolmom42
Bleach and other mold killers won't hurt it as long as you rinse it off thoroughly, like with a hose.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Y-Guy
Moderator
Moderator
After the winter I usually get some stuff growing on my awning. I've heard both of these products come recommended, Mold Armor or Tilex Mold & Mildew.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
theoldwizard1
Mold is usually black. Try some mild cleaner, like a squirt bottle of Simple Green. It may be easier to deal with it raised. A giid stiff brush also helps. A squirt bottle rinse would be good.
About the only thing that will get rid mold is bleach. You just need to be careful how strong your bleach solution and make sure you rinse it well.
I use Clorox CleanUp for a lot of things but I would cut it about 4 to 1 to start and see how it works. Mold normally will wipe right off with that stuff. If not, go to 2 to 1. The vinyl coated canvas is pretty tough.
