โJul-13-2017 06:17 AM
โJul-15-2017 10:12 AM
Rangerman40 wrote:
I don't lock mine...... it weighs 278lbs.
โJul-14-2017 07:34 PM
โJul-14-2017 03:05 PM
Gib3633 wrote:
I agree that Ram has the largest footprint and congratulate them for recognizing that. With the old cross rail system the truck box had a cross member support in the way of installing the hitch that would allow the king pin to be 2 inches ahead of the center of the rear axle. I haven't looked but I would think that would be the reason for the large spread. Ford has the smallest footprint but I see nothing wrong with it.
The gentleman I spoke with at B&W stated he wouldn't be concerned about pulling 20,000 lbs. on their 20,000 lb. hitch nor I but I already have a 20,000 hitch. I would think the reason B&W hasn't built the heavier hitch for GM yet is because they were a couple of years or so behind RAM & FORD to offer the puck system. Also possibly because GM rated their truck lower and their reason they stated was the biggest part of their customer base was hauling horse trailers and RVs around the 20,000 lb. mark.
This is way off OP's question so to that I don't lock mine in . I have a tonneau cover to hide it when not towing
โJul-14-2017 08:49 AM
โJul-14-2017 08:43 AM
โJul-14-2017 04:18 AM
Cummins12V98 wrote:
This is how I lock my US Made B&W 25K puck hitch to my bed. Opposing corners on the base, two on the head to base and one securing the latching handle.
I suppose a small padlock would fit where the pin is.
โJul-13-2017 08:21 PM
โJul-13-2017 06:26 PM
โJul-13-2017 06:15 PM
Gib3633 wrote:
Cummins
The difference is B&W do not make at this time a 24,000 lb. puck system hitch for GM. I thought you would know that since you are a RAM man.
The other difference is I have a 20,000 Reece and if I can't get what I would like I can wait. How do I know this?? because I called the factory and talked to the gentleman who answered the phone. The other comment about the contact surface to the king pin was my own observation. Maybe you should have a look.
If you would reread my comment you would see that I also preferred a B&W and explained why. I WANTED THE SAME HITCH YOU HAVE AND THEY DO NOT MAKE IT FOR GM.
โJul-13-2017 06:09 PM
ford truck guy wrote:
^^ Thanks Cummins, I was waiting for your input ! I know how much you like the B&W for good reason ! ! ! I figured it was only a matter of time till we saw how it was done right !
โJul-13-2017 03:49 PM
Gib3633 wrote:
Cummins
โJul-13-2017 03:24 PM
โJul-13-2017 01:51 PM
Cummins12V98 wrote:Gib3633 wrote:
I looked hard at those hitches and Curt was the only one making a 24,000 or 25,000 hitch for GM at this time. What I didn't like about the Curt hitch was the contact area pulling directly on the king pin was only about 3/16 of an inch of course backed up by about 5/8 inch. The B&W 20,000 lb. had a full 1 inch of contact to the pin. So I stayed with my 20,000 lb. Reese and bought Pullrite adaptors to utilize the puck system. I'm quite sure that down the road B&W will get with the program. I also have a tonno cover when not towing.
Call B&W and talk to them. They rate their hitches to the weakest link. Look at the Ford/GM system compare to the RAM's. Now tell me what is so different?
I would tow my 23K RV with the B&W Puck system with the Ford and GM any day before I would use the Curt. Yea, Yea I am a "FanBoy" but just look at these hitches side by side and then be real honest about what one you would trust.
โJul-13-2017 12:02 PM
