Jul-16-2015 05:15 AM
Jul-17-2015 11:59 AM
Jul-17-2015 07:06 AM
Jul-17-2015 02:26 AM
Jul-16-2015 03:48 PM
Dtank wrote:Arcamper wrote:
Our new Montana has a power fill only water tank and I try to check the gauge and stop at full but twice now I missed it and it started coming out of the vent. Montana says not to do this or damage can happen. I guess if you put water in faster than the vent can let it out you could over pressure the tank and burst it.
I slow it down now when its about 3/4 full.
Good plan........
Know the flow! - - especially using campground supply.
Some of 'em put out a LOT of volume!
*If* you must use an exterior *connection* to the RV, you may not know just what kind of quantity you are getting.....if you didn't check.
So check the campground hose bib - one turn gets you......
two turns, etc...;)
Jul-16-2015 03:41 PM
Jul-16-2015 02:31 PM
Jul-16-2015 01:55 PM
ford truck guy wrote:Excellent! When I posted earlier, I figured the response would be one of two things... Either "That's what I did and it works great", or "Don't do it - your fifth wheel will spontaneously explode like a nuclear bomb". I'm very happy to know that it was the former and not the latter. As soon as I figure out which of the two identical PEX lines is my fresh water tank overflow, I'm putting a valve in it. Thanks to AZ T&T, I'll also be putting the valve at the edge of the rig so I don't have to lay down under it. That had not even occurred to me before.AZ T&T wrote:I did this exact same thing... went to Home Depot and got the fittings needed.. I also diverted the drain line to the side of the camper...It got old laying down and crawling under the axles to turn the drain....Stefonius wrote:I had that problem also, I solved it by extending the over flow tube to the side of the FW and adding a small spigot.Lantley wrote:I have that problem too, and it makes me insane! I fill the tank until it starts to come out of the overflow, but then if the rig is tail down at all while setting up, it will siphon the tank dry and I can't stop it. Very frustrating when I'm boondocking, as I usually have to set up the RV nowhere near a spigot.
If I don't use the gauge and fill till it over flows than a siphon will start and my tank will drain itself onto the ground.
The only thing I can think to do is to plumb a shut-off into the overflow so that I can stop the tank from self-draining until I get level.
I keep the overflow vent spigot open at all times.. except directly after filling to break the siphon./..
Jul-16-2015 11:06 AM
Jul-16-2015 10:49 AM
CJW8 wrote:rr2254545 wrote:
Your tank holds right at 500 lbs of water - this surly is a lot to carry around
More like 776 LBs. 8.345 LB/ gallon @ 93 gallons.
Jul-16-2015 10:40 AM
AZ T&T wrote:Stefonius wrote:Lantley wrote:I have that problem too, and it makes me insane! I fill the tank until it starts to come out of the overflow, but then if the rig is tail down at all while setting up, it will siphon the tank dry and I can't stop it. Very frustrating when I'm boondocking, as I usually have to set up the RV nowhere near a spigot.
Jul-16-2015 09:26 AM
Jul-16-2015 09:15 AM
Jul-16-2015 09:00 AM
Jul-16-2015 07:47 AM
