Dec-02-2021 05:59 AM
Dec-06-2021 09:16 AM
Dec-06-2021 08:51 AM
JRscooby wrote:Cummins12V98 wrote:
FACT is if someone wanted to start :Bmaking roads out of asphalt and also adding chip seal to it and this technology was new there is NO WAY the greenies would let this ever happen.
And if we had started recycling tires before steel belts we would never had steel wire in tires.You EV people are living in Fantasy Island if you think your vehicles are "clean and green".
What is your solution? Burn it all down?
Dec-06-2021 08:14 AM
FACT is if someone wanted to start making roads out of asphalt and also adding chip seal to it and this technology was new there is NO WAY the greenies would let this ever happen.
Dec-06-2021 08:08 AM
Dec-06-2021 07:07 AM
Dec-06-2021 06:46 AM
Dec-06-2021 04:38 AM
Cummins12V98 wrote:sayoung wrote:Cummins12V98 wrote:
"What would you do in a state park?"
Clean what I could and throw it in a dumpster then kick gravel over it. What do you do every place your auto drips fluids on the ground?
You can't make this **** up ! My friend owns a sawmill/treating plant and during one state environmental inspection the lady inspector fined him because she found a millwright replacing a bad hydraulic hose that had ruptured and fluid was on the ground where he was working. She then tells him he could better control the dust on his plants dirt drives by spraying oil. The environment folks can be abserd
I know it's insane! Look what's poured on the roads to make a chip seal surface. Too many out their having to justify their jobs.
Dec-06-2021 03:05 AM
jsr21 wrote:SUMRX4 wrote:
Does cooler weather typically effect hydraulics operation. Winterized my unit last week and when I tried to close the main slides (hydraulic operated) they would move about 6" and stop and the touch screen would say "Fault occurred" I could release the control and touch it again and it would move about 6" and do the same thing. I'm thinking it was just because the fluid was cold and a little thicker. Does this seem typical and if so, is there an additive to help with this issue?
You have an auto reset breaker that is getting warm and tripping. They reset themselves in 4-5 seconds. Your pump has to work harder in cold weather to move the fluid and is warming up your breaker sooner than normal. It's normal and won't cause any damage so don't worry. If you want to improve it you could swap out the breaker with a higher amperage one...easy to do.
Dec-06-2021 02:57 AM
Dec-05-2021 03:46 PM
Dec-05-2021 01:26 PM
Dec-05-2021 09:15 AM
Dec-05-2021 06:23 AM
Dec-05-2021 04:15 AM
Cummins12V98 wrote:SUMRX4 wrote:enblethen wrote:
Cold will make hydraulics work slow. Some hydraulic systems use various types of fluid which effects system operation.
What system do you have and what fluid is in it?
Some hydraulic systems, not nessesarily rvs, have screens on the intake to the pump that can become restricted.
My unit is a new KZ Durango Gold with an LCI system. Have no idea what type of fluid is in it. Haven’t looked into that yet. Was just here searching for clues.
You should know where your tank is located and what the correct fluid is along with the correct fluid level and how to check it.
