JT's Strongarm install problem
ACZL
Am installing the JT's on our 5er and so far have the front brackets on but not the arms just yet. Had to quit at that time, not here on Sat and sick on Sun. So I figured I'd do the rear as it looks easy-peezy. It was until time to mount/attach the bracket to the rear crossmember. Only thing that's there is a 1/16" thick sheet metal that closes off the rear between the I-beams and it folds under approx 3/4". Have plastic belly to enclose the underside and this piece is attached to the sheet metal w/ 3 self tappers from the inside or from top.
So not only don't I have really firm metal to drill into, I don't have access to the 3 screws and this same piece of sheet metal is really a couple inches forward of the rear stabs as the arms will hit the rear stabs in full re-tract position.
Based with this info, it looks like I may have 2 choices which I'd like to get opinions on for those that have the JT's on their coaches.
1. Have a couple brackets made up and attach them to the rear cross section of the sheet metal (BUT this won't offer much in way of rigidity/strength) for the JT brackets to attach to.
2. Have a metal bar welded to rear of coach behind the sheet metal which would be stiffer/thicker, mount JT brackets to that and put the "T" handles/arms out of the way of the stabs.
I wish I knew how to post pics as then you'd better see what I'm up against.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
14 REPLIES 14
ACZL
Finally got the arms on today. The rear ones, I could not switch around. The "T" handle would have been directly behind the bumper making almost impossible to get to. So Will just use a bolt and 9/16"wrench. Bit more of a pain, but will work. Spray painted the angle iron when done w/ install of arms. Now the fun part and setting this up. Will look like 1st timers w/ a 5th wheel!! LOL
Learjet
ACZL wrote:
magic43 wrote:
Can you swap ends with the stabilizer which will put the T handle in a different position?
Not sure. According to the directions, the "T" and slide section are to be placed near the stab itself. Not sure of reasoning. As I write this, in thinking if the "T" was at top along w/ the slide section, might be a PITA trying to get to the "T" as I have bike rack attached to the bumper and would have to reach under/around bumper to get to it. When I go to add the extra washers, will see what it's like with it reversed.
It doesn't trap and hold water that way.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
ACZL
magic43
magic43
ACZL
Well DS and I took the 5er to the metal shop today and he welded on a 2x2 angle iron to top of brackets that hold the bumper on which in turn are welded to the I-beam itself. Then, and wasn't expecting this, he welded the 2 brackets for the arms to the angle iron. Cool! Now I don't have to fuss with them. One and only drawback overall is that the "T" handle will hit the stabilizers when in full re-tract position. So I may end up w/ just using a bolt in place of the "T" handle and tighten/loosen w/ a wrench. Otherwise, it looks good. Have to finish install of other arms and add washers to rear ones. Looking forward to see how it works.
Again, THANK YOU for the advice on what to do/mount the brackets.
lee_worsdell
on the back I just went to the bumper on an angle .They work fine
ACZL
Thanks for the replies!!! Glad I wasn't the only one who ran into a problem w/the rear ones. Will be taking 5er to a metal/welding Shop Fri so hopefully they can do their thing.
Scott_85
I had to install a piece of angle iron to the rear of my 5er also.
TV: 2013 Ram 2500 Laramie, G56, Andersen Ultimate 5th Wheel Hitch.
5er: 2013 Coachmen Chaparral 280RLS
Toolguy5
Specularius wrote:
I would bolt a piece of 1 1/2 inch angle iron across where needed. on.
This is what I did on mine.
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
BB_TX
I used a piece of 2"x2" sq tube cut the width of the frame and 45 degree angle on each end. Attached to the frame with self drilling screws. If you do not have the tools to cut it, any metal shop can cut the tube for you.
allen8106
Specularius wrote:
I would bolt a piece of 1 1/2 inch angle iron across where needed. On my last Fiver I attached the rear anchor points to a receiver hitch that was welded on.
Not a bad idea but uni-strut is stronger. Might cost a little more but worth it mu humble opinion.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
newman_fulltime
get a piece of 2 by 3 square stock cut a 45 on the ends bolt it to the frame on both sides and mount the strong arms to it
Peg_Leg
Just get a piece of 1.5x1.5 angle iron welded across the rear. You don't need much strength to stop the wiggling. Now if you forget to loosen the arms before lifting you may get a bend here or there.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Specularius
2015 F-350 DRW 6.7 Scorpion Diesel Reese Ford Hitch
2014 Grand Design Momentum 355TH
