My experience with a similar combination has been pleasant so far. We switched from a 10,600 lb dry/2100 pin Copper Canyon bunkhouse to a Fuzion 342 which is very similar weight wise to the 332TS. The 342 is a touch over 13,000 dry and listed at around 3090 on the pin. I'm pulling it with an '06 CC, LB, SRW 350, 11,500 GVWR, 15,500 max 5w rating. Thus far after a few trips I am very pleased at how well the truck controls the extra weight over our old bunkhouse. I'm not running any bags, although the pin weight does set it on the helpers. I get a touch more wiggle (very mild, nothing even remotely of concern) in the rear of the truck, but it's also sitting on fresh tires with full depth tread blocks instead of the well worn set I finished up on last season with the old 5er. This combo actually seems to ride better. Less bounce on the pin....I suppose due to the helpers coming into play now. Only drawback I see at this point is that I can't load it to the full 16,400 that the trailer is rated at. Our usage doesn't require it though.
