Large slideout blows fuse
Monty-Rob
I have a 2014 Lifestyle.
Before Evergreen closed their doors I got a new relay board for the large slideout from Dexter Axle. The slide now runs smoothly. Basically cut 50 feet of wiring to 8.
Bottom line is that after 4 to 5 times of using the slide the small 20amp fuse blows that is located in the front basement.
By the slide motor is a 25amp slow burn fuse.
20 amp Fuse always seems to blow after slide is in and I try to extend it.
I have a call in to the manufacturer (Dexter) but am open to any of your thoughts.
Thanks in advance...Rob
2014 Lifestyle 37CKLS (Sold January 2018)
2008 Ford F-450 Lariat (Sold January 2018)
2012 Started fulltiming on February 1st (stopped fulltiming December 21, 2017)
7 REPLIES 7
mountainsam
While you are lubricating those slides don't forget to put some "Slide Out Rubber Seal Conditioner" on the seals. It works magic reducing the drag of the seals when the slides are moving.
2017 Thor Gemini 23TR w/ 3.2 Power Stroke turbo diesel
2014 Ram 6.7 Cummins Turbo Diesel Crew Cab, Long Bed 4X4 6 Speed Auto (sold)
2013 Rockwood Signature 8281 WS w/Sidewinder Pin (sold)
DW and Sofie our Black Lab /Boxer and Phoebe our Schnoodle
Roger10378
Are you saying it only blows the fuse since you changed the board and wiring? If so there is something wrong with the new wiring. If the new was an attempt to fix the problem and didn't work then you need to check and see if the fuse is correct. Two fuses of different sizes in the same circuit doesn't make sense.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Monty-Rob
Thanks for suggestions...Rob
DirtyOil
Check the wiring to the slide drive motor, check for bare wires, "kinked" wiring, cracked wire insulation,melted wiring, connections at motor and any junction boxes. Wiring maybe getting "crimped" or connections are loose and maybe contacting a ground, when the slide is moving inwards causing a short which blowing the fuse.
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
filrupmark
Check the tag on the motor to see what full load amperage draw is and fuse accordingly. The slide may be blowing fuses due to lack of lubrication. I like dry Dupont Teflon lube . I spray it on all mechanical parts plus slide seals and the underside of our slide. It slides very smoothly. Use a slow blow fuse and not fast acting.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
tvman44
If one fuse is 25 amp slow blow the other needs to be at least the same. I would replace that 20 amp fuse. 🙂
Papa Bob
Husky 16K hitch, Tekonsha P3,
greende
I had a Keystone Cougar X-Lite TT that did that on day #1. CW adjusted the mechanism to minimize the draw to no avail. I eventually discovered that the wall switch was defective and would not turn off after I let go of the button. New switch & all was good. Not saying that's what your problem is, but something to think about.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
