Leaking Propane Regulator
thebig05
I have a 2016 Heartland Gateway. I've replaced the regulator twice on one side, and the leaks continue to come back. I've been trying to find the exact regulator with hose that came with as it seems the ones I'm replacing it with aren't to spec.
Any help would be appreciated.
12 REPLIES 12
time2roll
I would replace both regulators and the pigtails. I prefer Cavagna brand.
Bionic_Man
azdryheat wrote:
I got mine from Amazon.
I also got mine from Amazon. When I replaced it, I also replaced the small hoses that go from the regulator to the bottles. That was a couple of years ago.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
ItsyRV
The most important thing is knowing where it's leaking. Many people have replaced good working regulators because the in or out connections were leaking. Often when removing and replacing the regulator, they fix the leak at the connection (25 cents worth of yellow gas tape) making them think ti was the regulator because the leak stopped.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
azdryheat
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
thebig05
Thank you, all. You've all been a lot of help.
SidecarFlip
Lots of regulators on the market are cheap Chinese. Get a domestic one and be happy.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Is the regulator itself leaking (such as from the regulator's vent) or is the leak coming from the input or output connection? If it's coming from the vent, make sure it is the correct regulator. You may have replaced a high pressure (30 psi) regulator with a low pressure regulator. Been there, done that!
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
philh
Is it a flare fitting and you're attempting to use tape or goop, or it's not a flare fitting and you should use goop? Where exactly is the leak? soapy water is a good way to find the exact leak point.
BB_TX
Is it the regulator that looks like this one? Mine started leaking several years ago and I replaced it and no more leaks.
rbp111
I think it is smart to contact Heartland. That being said, I had a regulator go out after 3 years. It had 30 gpsi stamped on it. I checked with a dealer and bought a red regulator that was rated for 30 PSI. It is working now.
thebig05
Nothing that gives me the brand. I will try to contact Heartland.
agesilaus
Contact Heartland? You don't have a data sheet on the original with the documentation that they gave you with the RV?
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
