โApr-29-2016 05:46 PM
โMay-07-2016 08:15 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โMay-07-2016 05:47 AM
Reddog1 wrote:allendlung wrote:You should make it clear if you want 2WD or 4WD.
What are other good years of dodge trucks?
What should I look out for. I'm guessing I need to expand my budget, that's fine. I just want something that will last a long time.
If you do not mind smog check every two years, then a 1998 or newer is good. If you do not want smog, then you want 1997 or older.
In Texas at least, diesels are not subject to smog check regardless of year. I realize that will vary by state - the OP may want to check his state regulations.
Exhaust brakes on automatics in their stock form do not work until 2003 (I think). A torque converter upgrade is required and 60 lb exhaust valve springs are required pre-2003, as I recall. The torque converter must be able to lock up, and if so, the valves are subject to float without the 60 lb exhaust valve springs. The 60 lb valve spring change only applies to the Cummins 12V diesels used up to January 1, 1998. The Cummins 24V diesels do not require any mods to use an exhaust brake - they were set up to use the Jacobs brake from the factory, and it was a dealer-installed option. My 2002 had the Jacobs exhaust brake installed at the dealer before I took delivery, but it was a 6-speed manual. As you state, use of an exhaust brake with the 47RE automatic was "iffy" - many exhaust brake suppliers offered torque converter lockup and line pressure supplemental controls that were installed along with the exhaust brake when used with the 47RE.
The 1995 through 1997 and 1st half of 1998 do not use a computer for fuel, it is mechanical. Unlike the mid 1998 and newer do not have issues with the lift pump or injector pump.
I have had my 1996 since 2001. It is 2WD, and last time on the dyno I was at 250 hp. I get 17 to 19 MPG empty, and 12.5 to 13.5 with my 4000 lb TC. I have the mods above, and a less than year old $4,500 transmission with a triple disc converter. My 1996 is setup for 5th wheel, TC and TT. It has a U.S. Gear exhaust brake. It has been my pride and joy, with a list of modifications too long to list. I post this to suggest I am far from a stranger to the 5.9.My 2002 was an ETH/DEE (Cummins HO/NV5600 6-speed) 3500 2WD dually that was mildly "bombed" for towing with an Edge EZ, DD Stage 2 injectors, BHAF and 4" exhaust along with a South Bend CON O/FE clutch. It made 347/762 at the rear wheels and was extremely reliable. A really great towing machine, but my wife was never comfortable towing with the 6-speed manual - thus, our current truck.
OI really like my new to me 2004.5 DRW Quad cab due to its creature comforts, but in it's stock form it does not hold a candle to my 1996, power or MPG wise.
โMay-07-2016 05:13 AM
โMay-05-2016 08:27 PM
Toad: 91 Zuke
โMay-05-2016 01:46 PM
โMay-04-2016 08:40 PM
Chuck .. wrote:
My truck is a standard 99 diesel 2500 SLT 2 wheel drive, club cab with 3.54 rear end gears. GVWR is 8,800, rear end rating is 6084 and front GAWR is 4,410.
I am not the type to just throw caution to the wind and haul an RV that will tear up my truck and or put my family and others in danger.
When I was about 23 years old, I lost my brakes coming down a paved logging road with a full load of fire wood in the back end. The friends that were following me thought that I lost it and was somewhere down at the bottom of a ravine, dead. By the grace of God I didn't drive the truck over a cliff and was able to drive the old pickup truck through 25 mile per hour curve, going sideways doing 55 to 60.
If I had a Go-Pro camera in my truck, I could have made a movie and sold it to Hollywood for a million. I'm sure it would have scared the hell out of most stunt drivers! And it sure scared me!
When towing anything now, I drive like a "smart" old man down hills. Not a dumb young kid that lays six foot under in a cemetery.
โMay-04-2016 08:25 PM
โMay-04-2016 09:46 AM
Chuck .. wrote:
Please help me understand. I have a 1999 Dodge diesel 2500, Long bed, auto trans, cub cab, 2 wheel drive. The owner manual on page 148 says that this truck can tow maximum trailer weight of 10,200 with 3.54 axle ratio and 12,000 lbs maximum trailer with 4.10 axle ratio. The GCWR at the highest is 18,000.
I can't understand how you can operate/tow this unit safety and not tear up your truck? Most everyone on this forum and others said I can only haul a trailer around 9,000 lbs. "Dry Weight" safety and do not max out my truck!
โMay-04-2016 04:00 AM
โMay-04-2016 02:18 AM
โMay-03-2016 10:31 PM
โMay-03-2016 07:39 PM
โMay-02-2016 05:42 AM
RAS43 wrote:
While the 7.3 engines were considered more reliable then others, what must be considered is the newest model is now 13 years old and most will be high milers. The engine may be okay but the chassis and other components will need work. I had a '99 and in it's eighth year the high pressure oil system in the engine and the transmission failed. Both breakdowns were while traveling. Not very reliable IMHO. And this truck was well maintained thru it's life with me.
โMay-01-2016 05:52 PM
