Looking Washer Dryer Recommendations
Hitch_Itch
We just bought a 2017 Forest River Sandpiper 377FLIK.
It has a washer/dryer prep in the bedroom which is located in the back of the camper. We had a Splendide 2100XC in our last one, it was ok but did take forever to run the full cycle.
I'm wondering if there is a better option out there
Thanks
Hitch
Hitch
12 REPLIES 12
Hitch_Itch
Thanks for the input, I would definitely go with vented
Hitch
MichaelAtShawRV
Since everyone is saying the 2100XC by Splendide, then let me offer a counter-suggestion. There's the Pinnacle "Super Combo" Washer/Dryer combo units that come in vented and non-vented. Vented is always going to be better since the moisture takes longer to dissipate in a non-vented application. The price is about the same, if not a little more. Or, there's always the Dometic option for a washer/dryer combo unit but they only come in a ventless application. If you are considering a ventless unit, Countoure makes a nice combo unit with a bigger built-in hot water heater. Also they have dual fans on the inside for faster drying. Hope this helps!
djousma
If there is just one plug, vs one outlet plate with two plugs, then yes, a second circuit would need to be run to have stackables.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
Hitch_Itch
I only have 1 receptacle in the closet, can I do a stackable set with only one receptacle or would I need to add another one on its own circuit?
thanks again
Hitch
Hitch
TxGearhead
I think ours is a Pinnacle, vented. It shakes pretty good and I put rubber vibration isolators under the feet (Amazon? maybe). Helped a little. The wife uses it for just under wear and shirts. Took a while to figure out how to use the dry cycle. We bought some of those dryer balls that have pointed knobs, helped with wrinkles.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
djousma
Whirlpool stackable. Dryer is vented to the outside, runs on 120V. Works great! Came as factory option in my Cardinal. For me, the separate units allow for more efficiency, doing a wash and dry at the same time.
Even though the dryer is 120V, since the loads are all smaller than when done at home, everything seems to finish in about the same amount of time. My wife loves having them in the Cardinal when we are on our extended trips on full H/U.
Dave
edatlanta
I agree on the Splendide 2100XC which is vented. Who cares how long it takes, I'm retired.
The slow part is the drying cycle. You only have 120v vs 220v for a home unit. There is only so much heat available when are limited to 120v. Brand of dryer or stacked still takes longer to dry. Of course if stacked you can have a wet load ready to dry when the dryer is done.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
RainbowsEnd
Splendide vented
F250 Diesel Lariat
Laissez les bons temps rouler!
sch911
Splendide with the vent is the best we've had.
OEM Auto Engineer- Embedded Software Team
Halmfamily
We had a set of Whirlpools in our Sierra 360PDEK and they've been great, can stack them if needed.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
donn0128
Splendid vented. 11 years with only one problem. Slow, but who cares. It is a start and forget so no need to return to move wet clothes.
3_dog_nights
I bought a Danby washer from Walmart 4 years ago and have been very happy with it.
The spin cycle gets most of the water out and we hang the wash in the camper overnight to dry. Spent a third of the money, and pull it out in the winter so I don't worry about winterizing.
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
